跳转到主内容
PSP 300x Front Casing Replacement
kbrunner
kbrunner16 其他贡献者
最后更新于 March 24, 2025
5分钟
中等
不一致的图片
Steps for replacing the outer casing of a Sony PSP-3000.
你所需要的
配件
工具
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. PSP 300x Front Casing Replacement, Battery: 步骤 1 中的图像 1,3 PSP 300x Front Casing Replacement, Battery: 步骤 1 中的图像 2,3 PSP 300x Front Casing Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Front Casing Replacement, Front Casing: 步骤 2 中的图像 1,1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Front Casing Replacement: 步骤 3 中的图像 1,2 PSP 300x Front Casing Replacement: 步骤 3 中的图像 2,2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Front Casing Replacement: 步骤 4 中的图像 1,1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Front Casing Replacement: 步骤 5 中的图像 1,1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Front Casing Replacement: 步骤 6 中的图像 1,2 PSP 300x Front Casing Replacement: 步骤 6 中的图像 2,2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
结论
28等其他人完成本指南。
kbrunner
于11/05/09注册
81 声望
撰写一个指南
团队
Cal Poly, Team 19-2, Maness Fall 2009 Cal Poly, Team 19-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S19G2
3 名成员
创作了12篇指南
1指南评论
This is only the faceplate, not a casing replacement, come on
Dick - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 57
过去 30 天: 360
总计 19,822
