跳转到主内容
加入维修社区 - 创建账户
PS Vita Slim Buttons Replacement
你所需要的
    1. PS Vita Slim Buttons Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
      • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
      • There are four screws on the back of the device, remove them as shown.
      添加评论
    2. PS Vita Slim Buttons Replacement: 步骤 2 中的图像 1,2 PS Vita Slim Buttons Replacement: 步骤 2 中的图像 2,2
      • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
      • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
      询问修复机器人
      添加评论
    3. PS Vita Slim Buttons Replacement: 步骤 3 中的图像 1,3 PS Vita Slim Buttons Replacement: 步骤 3 中的图像 2,3 PS Vita Slim Buttons Replacement: 步骤 3 中的图像 3,3
      • The next step will require the opening tool.
      • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
      • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
      • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
      添加评论
    4. PS Vita Slim Buttons Replacement: 步骤 4 中的图像 1,1
      • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
      添加评论
    1. PS Vita Slim Buttons Replacement, Buttons: 步骤 5 中的图像 1,3 PS Vita Slim Buttons Replacement, Buttons: 步骤 5 中的图像 2,3 PS Vita Slim Buttons Replacement, Buttons: 步骤 5 中的图像 3,3
      • We are starting on the left side of the device. This is where the D-pad is, or in other words the left, right, up. and down directional pad.
      • The next step is to take the ribbon off of the green casing on the left.
      • Then simply unscrew the two screws holding down the green casing using a J00 bit from the iFixit pro toolkit, they should both be 6.35 mm .
      • Now simply raise the last restraint, a metal bar that is holding the casing down. Once it has been removed you can take off the green casing.
      询问修复机器人
      添加评论
    2. PS Vita Slim Buttons Replacement: 步骤 6 中的图像 1,2 PS Vita Slim Buttons Replacement: 步骤 6 中的图像 2,2
      • After the green casing has been taken off you should be able to see the back of the D-pad.
      • Once it is removed you should be free to interchange the buttons as needed.
      询问修复机器人
      添加评论
    3. PS Vita Slim Buttons Replacement: 步骤 7 中的图像 1,3 PS Vita Slim Buttons Replacement: 步骤 7 中的图像 2,3 PS Vita Slim Buttons Replacement: 步骤 7 中的图像 3,3
      • Now it is time for the right side buttons. Which is the replacement of the D-Pad on the right side or in other words, where the box, triangle, circle, and X buttons are.
      • First step is the removal of the ribbons on the green casing.
      • Once the ribbons have been removed, next you will want to remove the two 6.35 mm screws using the J00 screwdriver.
      • Now you should be able to remove the green casing.
      询问修复机器人
      添加评论
    4. PS Vita Slim Buttons Replacement: 步骤 8 中的图像 1,3 PS Vita Slim Buttons Replacement: 步骤 8 中的图像 2,3 PS Vita Slim Buttons Replacement: 步骤 8 中的图像 3,3
      • Once the green casing has been removed you are now be able to see the button pads that need to be removed.
      • The D-pad and other such buttons can now be replaced or simply cleaned.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
3指南评论
the ps button doesn't work, i have replaced the left d pad but it still doesn't work, where is the possible damage?
Eko Ferdiansyah - 回复 分享
Likely the board. Same thing happened to me, but with the square button. Button replacement didn't work and I had to replace the right board.
Josh Beoulve - 回复 分享
Slight correction on Step 8. This should be a J000, not 00. You'll end up stripping the screws if you're not careful.
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 60
过去 30 天: 310
总计 16,381
