跳转到主内容
加入维修社区 - 创建账户
PDP Rematch Top Left and Right Button(s) Replacement
你所需要的
  1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: 步骤 1 中的图像 1,2 PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    询问修复机器人
    添加评论
  2. PDP Rematch Top Left and Right Button(s) Replacement: 步骤 2 中的图像 1,2 PDP Rematch Top Left and Right Button(s) Replacement: 步骤 2 中的图像 2,2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    询问修复机器人
    添加评论
  3. PDP Rematch Top Left and Right Button(s) Replacement: 步骤 3 中的图像 1,2 PDP Rematch Top Left and Right Button(s) Replacement: 步骤 3 中的图像 2,2
    • Gently lift off the hard cover with your hand; it should not need much force.
    询问修复机器人
    添加评论
  4. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: 步骤 4 中的图像 1,2 PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: 步骤 4 中的图像 2,2
    • Remove the back panel by pulling it away from the front.
    • Disconnect the cable by squeezing the two sides while pulling the cable away from the motherboard.
    询问修复机器人
    添加评论
  5. PDP Rematch Top Left and Right Button(s) Replacement: 步骤 5 中的图像 1,2 PDP Rematch Top Left and Right Button(s) Replacement: 步骤 5 中的图像 2,2
    • Touch the hot tip of the soldering iron to the first solder connecting the buttons to the motherboard until the solder melts.
    • Repeat this for the next solder. Verify solders have detached from motherboard.
    • Be careful of the hot soldering tip.
    询问修复机器人
    添加评论
  6. PDP Rematch Top Left and Right Button(s) Replacement: 步骤 6 中的图像 1,2 PDP Rematch Top Left and Right Button(s) Replacement: 步骤 6 中的图像 2,2
    • When the solder has completely melted, flip the controller and gently pull the wire free from the motherboard.
    • Repeat for the other black wire.
    添加评论
结论
取消:我没有完成这个指南。
GraceGrubbs
于01/24/24注册
147 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 41
总计 507
