跳转到主内容
Ovation Acoustic Guitar String Replacement
Rachel Galvan
Rachel Galvan3 其他贡献者
最后更新于 December 29, 2022
15分钟
简单
If you have broken your Ovation Guitar string, use this guide to help you learn how to replace the string step by step. In this guide, you will learn how to not only replace the string, but learn how to implement a technique to prevent further guitar string breakage. Before using this guide, make sure inspect on how many strings are broken and if you have the correct strings.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Ovation Acoustic Guitar String Replacement, Guitar String: 步骤 1 中的图像 1,1
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: 步骤 2 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 2 中的图像 2,2
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: 步骤 3 中的图像 1,1
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: 步骤 4 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 4 中的图像 2,2
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: 步骤 5 中的图像 1,1
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: 步骤 6 中的图像 1,3 Ovation Acoustic Guitar String Replacement: 步骤 6 中的图像 2,3 Ovation Acoustic Guitar String Replacement: 步骤 6 中的图像 3,3
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: 步骤 7 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 7 中的图像 2,2
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: 步骤 8 中的图像 1,3 Ovation Acoustic Guitar String Replacement: 步骤 8 中的图像 2,3 Ovation Acoustic Guitar String Replacement: 步骤 8 中的图像 3,3
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: 步骤 9 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 9 中的图像 2,2
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
终点
Rachel Galvan
于04/07/21注册
169 声望
撰写一个指南
团队
CSU Los Angeles, Team S1-G6, Harris Fall 2021 CSU Los Angeles, Team S1-G6, Harris Fall 2021 的会员
CSULA-HARRIS-F21S1G6
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 32
总计 901
