跳转到主内容
Oral-B Vitality Power Button Replacement
Grady Bennett
Grady Bennett2 其他贡献者
最后更新于 April 19, 2022
30分钟
困难
Electric toothbrushes are powered on by a small on/off switch located on the outer case of the toothbrush handle. The on/off switch signals the circuit board to power the motor. If you press the power button and the toothbrush doesn't power on, most likely the power button needs to be replaced.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Oral-B Vitality Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Oral-B Vitality Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Oral-B Vitality Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: 步骤 2 中的图像 1,1
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: 步骤 3 中的图像 1,3 Oral-B Vitality Power Button Replacement: 步骤 3 中的图像 2,3 Oral-B Vitality Power Button Replacement: 步骤 3 中的图像 3,3
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: 步骤 4 中的图像 1,1
    • Attach the new button by soldering the 4 terminals with new solder.
结论
8等其他人完成本指南。
Grady Bennett
于11/07/17注册
506 声望
创作了2篇指南
团队
IUPUI, Team S2-G1, Harley Fall 2017 IUPUI, Team S2-G1, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S2G1
3 名成员
创作了9篇指南
5条评论
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - 回复
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - 回复
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - 回复
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
In my case the inside of the case of the toothbrush where the cover for the start button is, was worn. I cut 3 - 3/16" squares of electrical tape and placed it on top of the start switch. This filled the gap where the worn material was and enabled the switch to be activated easier. I also noticed that some moisture was inside the case of the toothbrush, so I coated the metal shaft protruding from the toothbrush, and the o ring of the cap with some water proof grease, Vaseline.
Robert Carl - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 118
总计 11,585
