跳转到主内容
加入维修社区 - 创建账户
Opening Philips EP-Models
你所需要的
    1. Opening Philips EP-Models, Philips EP Model Coffee Makers: 步骤 1 中的图像 1,2 Opening Philips EP-Models, Philips EP Model Coffee Makers: 步骤 1 中的图像 2,2
      • Never forget: Unplug the power cord!
      • Remove all attachments, like the water reservoir, the brewing chamber, the bean compartment lid, and the drip tray. Remove all of the coffee beans.
      • Turn the machine around so the back is facing you. Remove the two T10 Torx screws at the bottom edge. Pull out the back at the bottom edge and lift it down.
      • It's important that the parts are readily visible:
      • The motherboard
      • The pump
      • The flow meter
      • The heating element
      询问修复机器人
      添加评论
    2. Opening Philips EP-Models: 步骤 2 中的图像 1,1
      • Unscrew the three T10 Torx screws in the coffee bean compartment.
      询问修复机器人
      添加评论
    3. Opening Philips EP-Models: 步骤 3 中的图像 1,3 Opening Philips EP-Models: 步骤 3 中的图像 2,3 Opening Philips EP-Models: 步骤 3 中的图像 3,3
      • Remove all the beans from the opening on the finger guard of the grinder. A T10 Torx screw will become visible.
      • Unscrew the T10 Torx screw from the finger guard.
      • Lift the finger guard up.
      添加评论
    4. Opening Philips EP-Models: 步骤 4 中的图像 1,2 Opening Philips EP-Models: 步骤 4 中的图像 2,2
      • Slightly lift the top cover up at the back edge.
      • When putting it back together, make sure the grinder control is sitting right.
      询问修复机器人
      添加评论
    5. Opening Philips EP-Models: 步骤 5 中的图像 1,2 Opening Philips EP-Models: 步骤 5 中的图像 2,2
      • Pull the upper cover out from under the front cover and lay it slightly offset.
      • Remove both of the T10 Torx screws attached to the side covers.
      • You can remove the top cover completely, especially if you must work on the grinder. But, if you want to see the machine functioning later, then lay it back in its original place.
      • Picture 2 shows the grinder, which can now be easily taken off.
      • If you want to repair the grinder: here are the instructions Replacing the Philips ceramic grinder motor and sensor
      添加评论
    6. Opening Philips EP-Models: 步骤 6 中的图像 1,3 Opening Philips EP-Models: 步骤 6 中的图像 2,3 Opening Philips EP-Models: 步骤 6 中的图像 3,3
      • Both side panels are still screwed to the lower edge of the front. Unscrew both of the T10 Torx screws out from here.
      • Slide both side panels back a bit, and take them out from the bottom edge.
      添加评论
结论
Complete the steps in reverse order to reassemble your device.
取消:我没有完成这个指南。
9等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
338,488 声望
创作了311篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
38 名成员
创作了2,414篇指南
8指南评论
Leider stimmt diese Anleitung nicht für alle EP Modelle, ich besitze die Saeco Philips EP5960-10 diese zu öffnen ist eine Katastrophe. Da gibt es keine einzelne Wände, ich muss unbedingt unten an den Stromanschluss, da meine Maschine Plötzlich nicht mehr angeht, eventuell ist da eine Sicherung verbaut. Phillips will 200 € haben, da lege ich 100 drauf dann bekommt man was neues.
Michael Kollek - 回复 分享
Danke für den Hinweis. Diese Modelle gehen auf eine ältere Linie zurück. Vergleiche mit der Saeco Exprelia.
VauWeh - 回复 分享
VauWeh - 回复 分享
Die Saeco Minuto kommt meiner gleich, leider um unten an den Stromanschluss zu kommen, muss man alles ausbauen, was ein Mist.
Ja, etwas lästig, aber es geht. Die neuen EP- Modelle sind viel angenehmer.
VauWeh - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 42
过去 7 天: 449
过去 30 天: 1,791
总计 36,182
