跳转到主内容
加入维修社区 - 创建账户
OnePlus 8 Rear Glass Replacement
你所需要的
  1. OnePlus 8 Rear Glass Replacement, Heat the rear glass: 步骤 1 中的图像 1,1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
  2. OnePlus 8 Rear Glass Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
  3. OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: 步骤 3 中的图像 1,3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: 步骤 3 中的图像 2,3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: 步骤 3 中的图像 3,3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
  4. OnePlus 8 Rear Glass Replacement: 步骤 4 中的图像 1,3 OnePlus 8 Rear Glass Replacement: 步骤 4 中的图像 2,3 OnePlus 8 Rear Glass Replacement: 步骤 4 中的图像 3,3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  5. OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: 步骤 5 中的图像 1,3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: 步骤 5 中的图像 2,3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: 步骤 5 中的图像 3,3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: 步骤 6 中的图像 1,3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: 步骤 6 中的图像 2,3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: 步骤 6 中的图像 3,3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: 步骤 7 中的图像 1,3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: 步骤 7 中的图像 2,3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: 步骤 7 中的图像 3,3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
  8. OnePlus 8 Rear Glass Replacement, Remove the rear glass: 步骤 8 中的图像 1,3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: 步骤 8 中的图像 2,3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: 步骤 8 中的图像 3,3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
另外一个人完成了本指南。
Manuel Haeussermann
于07/13/22注册
23,431 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,130篇指南
1指南评论
hi, vielen Dank für die detaillierte Anleitung! Das hilft mega! Habt ihr evtl. noch eine Quelle, wo man das Backglass beziehen kann?
Thilo Cestonaro - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 83
总计 3,460
