跳转到主内容
加入维修社区 - 创建账户
OnePlus 6 Volume Button Replacement
你所需要的
    1. OnePlus 6 Volume Button Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      添加评论
    2. OnePlus 6 Volume Button Replacement: 步骤 2 中的图像 1,2 OnePlus 6 Volume Button Replacement: 步骤 2 中的图像 2,2
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      添加评论
    3. OnePlus 6 Volume Button Replacement: 步骤 3 中的图像 1,2 OnePlus 6 Volume Button Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      询问修复机器人
      添加评论
    1. OnePlus 6 Volume Button Replacement, Battery: 步骤 4 中的图像 1,2 OnePlus 6 Volume Button Replacement, Battery: 步骤 4 中的图像 2,2
      • Grip the green tab connected to the battery and pull the battery directly up and out.
      添加评论
    1. OnePlus 6 Volume Button Replacement, Fingerprint sensor: 步骤 5 中的图像 1,2 OnePlus 6 Volume Button Replacement, Fingerprint sensor: 步骤 5 中的图像 2,2
      • The midframe is made of plastic and located above the battery space.
      • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
      • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
      • Lift the bottom of the mid frame directly up and remove it from the device.
      添加评论
    1. OnePlus 6 Volume Button Replacement, Motherboard: 步骤 6 中的图像 1,1
      • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
      添加评论
    2. OnePlus 6 Volume Button Replacement: 步骤 7 中的图像 1,2 OnePlus 6 Volume Button Replacement: 步骤 7 中的图像 2,2
      • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
      • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
      • The cameras should lift up with the motherboard.
      添加评论
    1. OnePlus 6 Volume Button Replacement, Volume Button: 步骤 8 中的图像 1,1
      • Remove the two 2.3 mm screws using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. OnePlus 6 Volume Button Replacement: 步骤 9 中的图像 1,2 OnePlus 6 Volume Button Replacement: 步骤 9 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to lift up on the plastic tab that was held down by the screws.
      • Use the same pair of tweezers to lift up the metal tab underneath.
      • This is hinged on one side, so lift the open side first. The hinged side should pull out after the other side is up.
      询问修复机器人
      添加评论
    3. OnePlus 6 Volume Button Replacement: 步骤 10 中的图像 1,1
      • Using a pair of tweezers, remove the volume buttons from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G3
5 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 129
总计 8,550
