跳转到主内容
加入维修社区 - 创建账户
OnePlus 6 Midframe Replacement
你所需要的
    1. OnePlus 6 Midframe Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      添加评论
    2. OnePlus 6 Midframe Replacement: 步骤 2 中的图像 1,2 OnePlus 6 Midframe Replacement: 步骤 2 中的图像 2,2
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      添加评论
    3. OnePlus 6 Midframe Replacement: 步骤 3 中的图像 1,2 OnePlus 6 Midframe Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      询问修复机器人
      添加评论
    1. OnePlus 6 Midframe Replacement, Battery: 步骤 4 中的图像 1,2 OnePlus 6 Midframe Replacement, Battery: 步骤 4 中的图像 2,2
      • Grip the green tab connected to the battery and pull the battery directly up and out.
      添加评论
    1. OnePlus 6 Midframe Replacement, Fingerprint sensor: 步骤 5 中的图像 1,2 OnePlus 6 Midframe Replacement, Fingerprint sensor: 步骤 5 中的图像 2,2
      • The midframe is made of plastic and located above the battery space.
      • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
      • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
      • Lift the bottom of the mid frame directly up and remove it from the device.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G3
5 名成员
创作了96篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 27
过去 30 天: 82
总计 3,602
