简介
Follow this guide to remove the loudspeaker assembly from a OnePlus 5. The hardest part is getting the frame clips free. Once that is done, the speaker assembly comes out easily.
你所需要的
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
Press firmly to eject the tray.
Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Repair didn’t go as planned? Check out our OnePlus 5 Answers community for troubleshooting help.
