跳转到主内容
加入维修社区 - 创建账户
OnePlus 5 Daughterboard Replacement
你所需要的
  1. OnePlus 5 Daughterboard Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 OnePlus 5 Daughterboard Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 OnePlus 5 Daughterboard Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
  2. OnePlus 5 Daughterboard Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
  3. OnePlus 5 Daughterboard Replacement: 步骤 3 中的图像 1,3 OnePlus 5 Daughterboard Replacement: 步骤 3 中的图像 2,3 OnePlus 5 Daughterboard Replacement: 步骤 3 中的图像 3,3
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 5 Daughterboard Replacement: 步骤 4 中的图像 1,2 OnePlus 5 Daughterboard Replacement: 步骤 4 中的图像 2,2
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
  5. OnePlus 5 Daughterboard Replacement: 步骤 5 中的图像 1,3 OnePlus 5 Daughterboard Replacement: 步骤 5 中的图像 2,3 OnePlus 5 Daughterboard Replacement: 步骤 5 中的图像 3,3
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 5 Daughterboard Replacement: 步骤 6 中的图像 1,2 OnePlus 5 Daughterboard Replacement: 步骤 6 中的图像 2,2
    • Lever the opening tool to release the first clip from the frame.
  7. OnePlus 5 Daughterboard Replacement: 步骤 7 中的图像 1,3 OnePlus 5 Daughterboard Replacement: 步骤 7 中的图像 2,3 OnePlus 5 Daughterboard Replacement: 步骤 7 中的图像 3,3
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  8. OnePlus 5 Daughterboard Replacement: 步骤 8 中的图像 1,1
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
  9. OnePlus 5 Daughterboard Replacement: 步骤 9 中的图像 1,3 OnePlus 5 Daughterboard Replacement: 步骤 9 中的图像 2,3 OnePlus 5 Daughterboard Replacement: 步骤 9 中的图像 3,3
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
  10. OnePlus 5 Daughterboard Replacement: 步骤 10 中的图像 1,2 OnePlus 5 Daughterboard Replacement: 步骤 10 中的图像 2,2
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
  11. OnePlus 5 Daughterboard Replacement: 步骤 11 中的图像 1,2 OnePlus 5 Daughterboard Replacement: 步骤 11 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  12. OnePlus 5 Daughterboard Replacement: 步骤 12 中的图像 1,1
    • Remove the back cover.
  13. OnePlus 5 Daughterboard Replacement, OnePlus 5 Battery Disconnect: 步骤 13 中的图像 1,2 OnePlus 5 Daughterboard Replacement, OnePlus 5 Battery Disconnect: 步骤 13 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
  14. OnePlus 5 Daughterboard Replacement, Loudspeaker: 步骤 14 中的图像 1,1
    • Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
  15. OnePlus 5 Daughterboard Replacement: 步骤 15 中的图像 1,2 OnePlus 5 Daughterboard Replacement: 步骤 15 中的图像 2,2
    • Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
  16. OnePlus 5 Daughterboard Replacement: 步骤 16 中的图像 1,1
    • Remove the loudspeaker.
    • To reinstall the loudspeaker, align the loudspeaker's bottom edge to the frame, then press the assembly into place.
    • During reinstallation, make sure that the display cable connector under the loudspeaker assembly is still securely fastened.
  17. OnePlus 5 Daughterboard Replacement, OnePlus 5 Interconnect Cable Disconnect: 步骤 17 中的图像 1,3 OnePlus 5 Daughterboard Replacement, OnePlus 5 Interconnect Cable Disconnect: 步骤 17 中的图像 2,3 OnePlus 5 Daughterboard Replacement, OnePlus 5 Interconnect Cable Disconnect: 步骤 17 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
    • If you are replacing the battery, bend the interconnect flex cable away from the phone and secure it out of the way with a rubber band or tape.
  18. OnePlus 5 Daughterboard Replacement, Daughterboard: 步骤 18 中的图像 1,2 OnePlus 5 Daughterboard Replacement, Daughterboard: 步骤 18 中的图像 2,2
    • Use the point of a spudger the pry up and disconnect the fingerprint scanner connector from its socket on the daughterboard.
  19. OnePlus 5 Daughterboard Replacement: 步骤 19 中的图像 1,3 OnePlus 5 Daughterboard Replacement: 步骤 19 中的图像 2,3 OnePlus 5 Daughterboard Replacement: 步骤 19 中的图像 3,3
    • Slip the point of a spudger underneath the antenna interconnect cable and pry up to disconnect it from its socket on the daughterboard.
    • De-route the antenna interconnect cable out of the way of the daughterboard.
  20. OnePlus 5 Daughterboard Replacement: 步骤 20 中的图像 1,2 OnePlus 5 Daughterboard Replacement: 步骤 20 中的图像 2,2
    • Insert the edge of a flat end of the spudger underneath the microphone board and twist slightly to release the board's adhesive.
  21. OnePlus 5 Daughterboard Replacement: 步骤 21 中的图像 1,3 OnePlus 5 Daughterboard Replacement: 步骤 21 中的图像 2,3 OnePlus 5 Daughterboard Replacement: 步骤 21 中的图像 3,3
    • Slide the flat end of a spudger or the point of an opening pick underneath the daughterboard near its right edge.
    • Gently pry to loosen the daughterboard from its recess.
    • If the daughterboard begins to bend significantly, stop and pry from a different angle.
  22. OnePlus 5 Daughterboard Replacement: 步骤 22 中的图像 1,3 OnePlus 5 Daughterboard Replacement: 步骤 22 中的图像 2,3 OnePlus 5 Daughterboard Replacement: 步骤 22 中的图像 3,3
    • Insert the flat end of a spudger underneath the daughterboard, this time approaching it from the bottom.
    • Twist and slide the spudger slightly to release the daughterboard from its recess.
  23. OnePlus 5 Daughterboard Replacement: 步骤 23 中的图像 1,1
结论
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
另外一个人完成了本指南。
Arthur Shi
于01/03/18注册
316,790 声望
创作了730篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,992篇指南
2指南评论
Thank you so much.
Yasin Sil - 回复
Hi ! My microphone was damaged so I bought a replacement daughterboard but neither the microphone nor the speakers worked after installing it :(
I reinstalled the old one with the damaged microphone and the speakers worked fine. Any idea what could cause the issue ?
jeremie gabolde - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 126
总计 1,938
