跳转到主内容
OnePlus 2 Front and Rear Camera Replacement
Kayla Williams
Kayla Williams5 其他贡献者
最后更新于 May 7, 2024
15分钟
中等
If your front and or rear cameras have stopped taking clear picutres, it may be necessary to replace them. If that is the case, this guide will help you do that.
你所需要的
工具
查看更多...
  1. OnePlus 2 Front and Rear Camera Replacement, SIM Card: 步骤 1 中的图像 1,3 OnePlus 2 Front and Rear Camera Replacement, SIM Card: 步骤 1 中的图像 2,3 OnePlus 2 Front and Rear Camera Replacement, SIM Card: 步骤 1 中的图像 3,3
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Front and Rear Camera Replacement: 步骤 2 中的图像 1,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 2 中的图像 2,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 2 中的图像 3,3
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Front and Rear Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the SIM card tray
  4. OnePlus 2 Front and Rear Camera Replacement, Battery: 步骤 4 中的图像 1,3 OnePlus 2 Front and Rear Camera Replacement, Battery: 步骤 4 中的图像 2,3 OnePlus 2 Front and Rear Camera Replacement, Battery: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
  5. OnePlus 2 Front and Rear Camera Replacement: 步骤 5 中的图像 1,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 5 中的图像 2,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 5 中的图像 3,3
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Front and Rear Camera Replacement: 步骤 6 中的图像 1,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 6 中的图像 2,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 6 中的图像 3,3
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
  7. OnePlus 2 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 7 中的图像 1,3 OnePlus 2 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 7 中的图像 2,3 OnePlus 2 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 7 中的图像 3,3
    • Use the spudger tool to pry off the connections at the bottom-right of the front-facing camera.
    • Be sure to disconnect both connections before attempting to lift off the wiring.
  8. OnePlus 2 Front and Rear Camera Replacement: 步骤 8 中的图像 1,2 OnePlus 2 Front and Rear Camera Replacement: 步骤 8 中的图像 2,2
    • Use the spudger tool to pry off the connection on the left of the front facing camera.
  9. OnePlus 2 Front and Rear Camera Replacement: 步骤 9 中的图像 1,2 OnePlus 2 Front and Rear Camera Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the tweezers to lift up the camera from its groove.
    • The camera has a long, flat portion at the bottom, so be sure to slide the camera up while lifting it up.
  10. OnePlus 2 Front and Rear Camera Replacement: 步骤 10 中的图像 1,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 10 中的图像 2,3 OnePlus 2 Front and Rear Camera Replacement: 步骤 10 中的图像 3,3
    • Use a spudger to pry off the connection below the front-facing camera.
    • Using the tweezers, carefully remove the camera from its groove.
结论
5等其他人完成本指南。
Kayla Williams
于10/01/15注册
1,544 声望
创作了6篇指南
团队
Cal Poly, Team 4-5, Maness Fall 2015 Cal Poly, Team 4-5, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G5
4 名成员
创作了19篇指南
5条评论
This is awesome guide. My 20 days old onePlus2 lens broke, when my pocket hit the table while I had the phone in there. After reading in the forum about the OnePlus customer service, I did not bother calling OnePlus. I ordered the lens for $5 from parts4repair.com. Followed this awesome directions and replaced the lens without a glitch.
BIG BIG BIG KUDOS to Kayla Williams. This really saved me a lot of time and trouble and made my phone worth again. I can't thank you enough.
Ramesh - 回复
Dude does that camera lens was real.. I mean like Lens do work like original lens earlier it was? Please reply ASAP!! My camera lens is also broken
Shubham -
This is a really good guide. My 2 month old one plus 2 was denied service due to some water damage policy. A drop of sweat might have gone in and the service centre says the product is water damaged.
Can you help me with some website where I can find the back camera for one plus 2 please?
Aman Srivastava - 回复
Hey guys! My OPT fell off a rollercoaster and fortunatly the glass isn't broken at all, but my front camera is damaged. This guide helped me a lot but I can't find that part.
Sadly parts4repair has no front camera lens in its sortiment. Can you give me some websites where I can find the parts
Alex Pulz - 回复
Have you found any replacement parts? I'm facing the same issue atm
Maarten -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 30
总计 5,196
