跳转到主内容
加入维修社区 - 创建账户
OnHub OnHub Antenna Array Replacement
你所需要的
    1. OnHub OnHub Antenna Array Replacement, Speaker Grille: 步骤 1 中的图像 1,2 OnHub OnHub Antenna Array Replacement, Speaker Grille: 步骤 1 中的图像 2,2
      • Make sure the device is unplugged before proceeding with the disassembly.
      • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
      询问修复机器人
      添加评论
    2. OnHub OnHub Antenna Array Replacement: 步骤 2 中的图像 1,1
      • Place the plastic opening tool under the speaker grille, and just above the light ring.
      • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
      询问修复机器人
      添加评论
    3. OnHub OnHub Antenna Array Replacement: 步骤 3 中的图像 1,2 OnHub OnHub Antenna Array Replacement: 步骤 3 中的图像 2,2
      • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
      • There is a delicate wire connection to the antenna that is easily broken if not careful.
      询问修复机器人
      添加评论
    1. OnHub OnHub Antenna Array Replacement, Congestion-sensing Antenna: 步骤 4 中的图像 1,2 OnHub OnHub Antenna Array Replacement, Congestion-sensing Antenna: 步骤 4 中的图像 2,2
      • Remove the wire connection to the antenna by soldering it off.
      • For help with soldering and de-soldering check out the iFixit Soldering Guide
      询问修复机器人
      添加评论
    1. OnHub OnHub Antenna Array Replacement, Outer Casing: 步骤 5 中的图像 1,2 OnHub OnHub Antenna Array Replacement, Outer Casing: 步骤 5 中的图像 2,2
      • You must remove the plastic cover found just above the speaker.
      • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
      • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
      • Though the snapping noise is normal, take care not to break these clips.
      询问修复机器人
      添加评论
    2. OnHub OnHub Antenna Array Replacement: 步骤 6 中的图像 1,1
      • Upon removing the cover, four screws and the speaker housing will be exposed.
      • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
      • This unlocks the speaker housing and antenna array from the casing.
      询问修复机器人
      添加评论
    3. OnHub OnHub Antenna Array Replacement: 步骤 7 中的图像 1,2 OnHub OnHub Antenna Array Replacement: 步骤 7 中的图像 2,2
      • On the bottom of the OnHub is two screws holding the casing to the base.
      • To access these screws, you must remove the rubber pad that is glued to the base.
      • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
      • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
      • The rubber pad is thin and fragile; be careful not to tear when removing.
      询问修复机器人
      添加评论
    4. OnHub OnHub Antenna Array Replacement: 步骤 8 中的图像 1,1
      • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
      询问修复机器人
      添加评论
    5. OnHub OnHub Antenna Array Replacement: 步骤 9 中的图像 1,2 OnHub OnHub Antenna Array Replacement: 步骤 9 中的图像 2,2
      • Once the two screws are removed from the base, it is time to split the casing apart.
      • It is okay if a couple clips break. It will still hold together with a few remaining.
      • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
      • There are three hooking style clips in total.
      询问修复机器人
      添加评论
    6. OnHub OnHub Antenna Array Replacement: 步骤 10 中的图像 1,1
      • Once unclipped, you can slide the two casing halves apart, and remove the casing.
      询问修复机器人
      添加评论
    1. OnHub OnHub Antenna Array Replacement, Speaker: 步骤 11 中的图像 1,2 OnHub OnHub Antenna Array Replacement, Speaker: 步骤 11 中的图像 2,2
      • Underneath the speaker is an intertwined black and white wire.
      • Disconnect the wire from its connection to the motherboard.
      询问修复机器人
      添加评论
    2. OnHub OnHub Antenna Array Replacement: 步骤 12 中的图像 1,1
      • The speaker should now easily come off with a firm grip on the OnHub device and pull.
      询问修复机器人
      添加评论
    1. OnHub OnHub Antenna Array Replacement, OnHub Antenna Array: 步骤 13 中的图像 1,1
      • There is a black, horizontal brace covering 12 wire connections.
      • Remove the brace, held by two screws
      询问修复机器人
      添加评论
    2. OnHub OnHub Antenna Array Replacement: 步骤 14 中的图像 1,2 OnHub OnHub Antenna Array Replacement: 步骤 14 中的图像 2,2
      在这个步骤中使用的工具:
      • Make a note of each wire's position and color, so it will be easier to reconnect later.
      • Using tweezers, gently disconnect each of the 12 wire connections, attached to the top of the motherboard.
      • Be careful when removing the gold connectors as they are easily bent.
      • The connection points can be bent back if not damaged too badly.
      询问修复机器人
      添加评论
    3. OnHub OnHub Antenna Array Replacement: 步骤 15 中的图像 1,1
      • Make sure to carefully pull the tape style wire furthest to the left that is held by glue.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Mahir Abdella
于02/10/16注册
331 声望
创作了2篇指南
团队
USF Tampa, Team 3-3, Sullivan Spring 2016 USF Tampa, Team 3-3, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S3G3
3 名成员
创作了15篇指南
1指南评论
That’s not a “tape-style wire”, that’s a ZIF flex cable! (ZIF is short for Zero Insertion Force)
To unplug that flex cable (which connects the LEDs to the main board) flip the little black bit at the other side of the connector up, then pull out the cable.
Jefferson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 925
