跳转到主内容
加入维修社区 - 创建账户
Nook Simple Touch with GlowLight Screen Replacement
你所需要的
    1. Nook Simple Touch with GlowLight Screen Replacement, Power Button: 步骤 1 中的图像 1,1
      • Place the Nook with the screen facing down.
      询问修复机器人
      添加评论
    2. Nook Simple Touch with GlowLight Screen Replacement: 步骤 2 中的图像 1,1
      • Wedge the opening tool between the power button and the upper edge of the device.
      • Push the opening tool down to pry the power button up.
      添加评论
    3. Nook Simple Touch with GlowLight Screen Replacement: 步骤 3 中的图像 1,1
      • Using your fingers, gently remove the power button.
      添加评论
    1. Nook Simple Touch with GlowLight Screen Replacement, Back Cover: 步骤 4 中的图像 1,1
      • Remove the single screw using a T4 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Nook Simple Touch with GlowLight Screen Replacement: 步骤 5 中的图像 1,1
      • Slide the back cover down towards you in the direction of the charging port.
      询问修复机器人
      添加评论
    1. Nook Simple Touch with GlowLight Screen Replacement, Battery: 步骤 6 中的图像 1,2 Nook Simple Touch with GlowLight Screen Replacement, Battery: 步骤 6 中的图像 2,2
      • Detach the white cable connector from the motherboard.
      • Remove the battery from the device.
      询问修复机器人
      添加评论
    1. Nook Simple Touch with GlowLight Screen Replacement, Motherboard: 步骤 7 中的图像 1,1
      • Remove eleven screws from the motherboard using the T4 screwdriver.
      询问修复机器人
      添加评论
    2. Nook Simple Touch with GlowLight Screen Replacement: 步骤 8 中的图像 1,3 Nook Simple Touch with GlowLight Screen Replacement: 步骤 8 中的图像 2,3 Nook Simple Touch with GlowLight Screen Replacement: 步骤 8 中的图像 3,3
      • Disconnect the orange ribbon cable from the motherboard.
      • Using your fingers, gently lift the motherboard from the display.
      询问修复机器人
      添加评论
    1. Nook Simple Touch with GlowLight Screen Replacement, Screen: 步骤 9 中的图像 1,2 Nook Simple Touch with GlowLight Screen Replacement, Screen: 步骤 9 中的图像 2,2
      • Insert the iFixit opening tool between the display and the front case.
      • Gently move to iFixit opening tool around the perimeter to release the set of tape strips.
      询问修复机器人
      添加评论
    2. Nook Simple Touch with GlowLight Screen Replacement: 步骤 10 中的图像 1,2 Nook Simple Touch with GlowLight Screen Replacement: 步骤 10 中的图像 2,2
      • Turn the display over. Pry the display bezel from the display assembly with the iFixit opening tool.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 47
总计 1,490
