跳转到主内容
Nook HD Button Replacement
Julian Lohser
Julian Lohser4 其他贡献者
最后更新于 June 13, 2019
15 - 30 分钟
中等
更好的介绍
你所需要的
工具
查看更多...
  1. Nook HD Button Replacement, Case: 步骤 1 中的图像 1,3 Nook HD Button Replacement, Case: 步骤 1 中的图像 2,3 Nook HD Button Replacement, Case: 步骤 1 中的图像 3,3
    • Be sure the device is powered off. Clean the device to prevent any dirt and dust from entering into the device.
    • Use the plastic opening tool to gently pry the plastic screen frame away from the screen. Run the plastic opening tool along the interior edge of the screen until the screen frame is completely separated from the glass.
    • The screen frame is held onto the Nook by a set of tab that run around the outside of the frame. There may also be a line of rubber cement around the Nook under the screen frame. If your Nook has this, you will have to dig deep to separate the frame from the Nook.
  2. Nook HD Button Replacement: 步骤 2 中的图像 1,2 Nook HD Button Replacement: 步骤 2 中的图像 2,2
    • Use a T5 screwdriver to remove the seventeen 5.0 millimeter screws from the back casing.
  3. Nook HD Button Replacement: 步骤 3 中的图像 1,3 Nook HD Button Replacement: 步骤 3 中的图像 2,3 Nook HD Button Replacement: 步骤 3 中的图像 3,3
    • Slowly pull the back casing away from the screen and motherboard.
    • There is a cable attaching the battery in the back plate to the motherboard. Avoid detaching either end of the cable during this step.
  4. Nook HD Button Replacement: 步骤 4 中的图像 1,3 Nook HD Button Replacement: 步骤 4 中的图像 2,3 Nook HD Button Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to gently unclip the wire from the pins by pulling the white connector up.
  5. Nook HD Button Replacement, Motherboard: 步骤 5 中的图像 1,2 Nook HD Button Replacement, Motherboard: 步骤 5 中的图像 2,2
    • There are three ribbon cable connections that you must disconnect in order to remove the motherboard.
    • The first of these connections is small black - grey plastic connection housing.
    • Use the plastic opening tool to pull the black part of the ribbon cable housing up and away from the circuit board.
    • Carefully pull the ribbon cable out of the plastic connection housing.
  6. Nook HD Button Replacement: 步骤 6 中的图像 1,1
    • The second of these connections is a small white - tan plastic connection housing.
    • Use the plastic opening tool to pull the tan part of the housing up and away from the circuit board.
  7. Nook HD Button Replacement: 步骤 7 中的图像 1,1
    • The final connection is a large orange ribbon cable that connects to an entirely separate circuit board.
    • Use the plastic opening tool to gently pry the cable away from the smaller circuit board as to disconnect the cable from the pins.
  8. Nook HD Button Replacement: 步骤 8 中的图像 1,1
    • Use the T5 torx screwdriver to remove the four 2.5 millimeter screws that attach the motherboard to the back plate.
  9. Nook HD Button Replacement: 步骤 9 中的图像 1,1
    • Gently pull the motherboard straight off of the back plate.
  10. Nook HD Button Replacement, Button: 步骤 10 中的图像 1,2 Nook HD Button Replacement, Button: 步骤 10 中的图像 2,2
    • Using the plastic opening tool, lever the button arms towards the center of the nook so the button mechanism slides free.
    • Check moving parts for dust or other obstructions and contacts for insulators.
结论
2等其他人完成本指南。
Julian Lohser
于04/17/14注册
101 声望
撰写一个指南
团队
Cal Poly, Team 3-43, Maness Spring 2014 Cal Poly, Team 3-43, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G43
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 21
总计 1,631
