跳转到主内容
加入维修社区 - 创建账户
Nook BNRV300 Power Button Replacement
你所需要的
    1. Nook BNRV300 Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Nook BNRV300 Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Nook BNRV300 Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
      • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
      • Turn the Nook over to find the power button along the back upper edge.
      • Wedge the spudger between the top of the power button and the upper edge of the device.
      • Push the tool down to pry the button up and off.
      添加评论
    2. Nook BNRV300 Power Button Replacement: 步骤 2 中的图像 1,1
      • Using your fingers, take off the power button.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2指南评论
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - 回复 分享
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 1,420
