跳转到主内容
Nokia E90 Front Cover Replacement
Cameron Weinberg
Cameron Weinberg4 其他贡献者
最后更新于 January 10, 2025
3 - 5 分钟
简单
不正确的工具
This guide requires a T5 screwdriver for the screws.
你所需要的
工具
  1. Nokia E90 Front Cover Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Front Cover Replacement: 步骤 2 中的图像 1,2 Nokia E90 Front Cover Replacement: 步骤 2 中的图像 2,2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G21
3 名成员
创作了8篇指南
2条评论
I have a n90 done which will not switch on. I have changed the battery and still nothing.pressing the top power button but nothing.trying to get old pics off the phone any help?
Smith - 回复
Hello Mr Smith. Have you tried to recharge the battery as it is in the phone in question? Recharge the battery while it is in the phone first, IF the phone in question still does not boot up then get another battery from ebay. I have a similar E90 as yours and the battery did go flat in the end, like all batteries, I just got a new battery and then recharged the battery while it is in the phone. Good luck.
Keith N Searle -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 4,995
