跳转到主内容
Nokia E90 Battery Cover and Battery Replacement
michael mira
michael mira3 其他贡献者
最后更新于 January 28, 2014
30秒
非常容易
This repair guide shows how to remove the battery from the Nokia E90 cellphone. It involves three simple steps and there are no tools required.
  1. Nokia E90 Battery Cover and Battery Replacement, Battery Cover and Battery: 步骤 1 中的图像 1,1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 Battery Cover and Battery Replacement: 步骤 2 中的图像 1,2 Nokia E90 Battery Cover and Battery Replacement: 步骤 2 中的图像 2,2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 Battery Cover and Battery Replacement: 步骤 3 中的图像 1,1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
结论
To reassemble the back cover, simply slide it back on.
另外一个人完成了本指南。
michael mira
于04/26/11注册
14 声望
撰写一个指南
团队
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G21
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 5,486
