跳转到主内容
Nokia 8265 Logic Board Replacement
Jack
Jack7 其他贡献者
最后更新于 January 3, 2024
10分钟
中等
不正确的工具
需要更好的图片
How to take out and replace the Logic Board for the Nokia 8265 Cell Phone.
你所需要的
工具
  1. Nokia 8265 Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,1
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Logic Board Replacement: 步骤 4 中的图像 1,1
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Logic Board Replacement: 步骤 5 中的图像 1,1
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
    • The screen section will be able to be removed after Step 4 is finished.
  6. Nokia 8265 Logic Board Replacement: 步骤 6 中的图像 1,1
    • Be careful when removing the Logic Board from the body, lifting it with fingers on both sides to prevent damage of the Logic Board.
    • Separate the Logic Board from the main body of the device.
  7. Nokia 8265 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
  8. Nokia 8265 Logic Board Replacement: 步骤 8 中的图像 1,1
    • Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
  9. Nokia 8265 Logic Board Replacement: 步骤 9 中的图像 1,1
    • Replace screws in the corresponding slots, tightening them till they are not loose.
  10. Nokia 8265 Logic Board Replacement: 步骤 10 中的图像 1,1
    • Replace keypad onto the device
  11. Nokia 8265 Logic Board Replacement: 步骤 11 中的图像 1,1
    • Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
终点
Jack
于04/20/12注册
1 声望
创作了4篇指南
团队
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 的会员
SUNYCORT-GETTO-S12S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,206
