跳转到主内容
Nokia 6560 keypad replacement or cleaning
Tim Bergmann
Tim Bergmann7 其他贡献者
最后更新于 October 29, 2017
10分钟
简单
This guide explains how to clean and replace the keypad of your cell phone.
你所需要的
工具
  1. Nokia 6560 keypad replacement or cleaning, Battery: 步骤 1 中的图像 1,2 Nokia 6560 keypad replacement or cleaning, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 keypad replacement or cleaning: 步骤 2 中的图像 1,2 Nokia 6560 keypad replacement or cleaning: 步骤 2 中的图像 2,2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 keypad replacement or cleaning, Keypad: 步骤 3 中的图像 1,2 Nokia 6560 keypad replacement or cleaning, Keypad: 步骤 3 中的图像 2,2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 keypad replacement or cleaning: 步骤 4 中的图像 1,2 Nokia 6560 keypad replacement or cleaning: 步骤 4 中的图像 2,2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
结论
3等其他人完成本指南。
Tim Bergmann
于01/18/10注册
35 声望
创作了4篇指南
团队
Cal Poly, Team 3-17, Maness Winter 2010 Cal Poly, Team 3-17, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G17
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,247
