跳转到主内容
Nokia 6102i Outside Display Screen Replacement
Jonathan Brophy
Jonathan Brophy6 其他贡献者
最后更新于 February 19, 2016
15 - 20 分钟
中等
不一致的图片
Removing the outer display from the Nokia 6102i
你所需要的
工具
  1. Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: 步骤 1 中的图像 1,3 Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: 步骤 1 中的图像 2,3 Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: 步骤 1 中的图像 3,3
    • This step does not require much force.
    • Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen.
  2. Nokia 6102i Outside Display Screen Replacement, Remove Phone Case Screws.: 步骤 2 中的图像 1,2 Nokia 6102i Outside Display Screen Replacement, Remove Phone Case Screws.: 步骤 2 中的图像 2,2
    • Have a container ready to keep track of small parts.
    • Use the t6 screwdriver to remove the two visible screws that are immediately below the screen.
  3. Nokia 6102i Outside Display Screen Replacement, Remove silver and black phone case: 步骤 3 中的图像 1,2 Nokia 6102i Outside Display Screen Replacement, Remove silver and black phone case: 步骤 3 中的图像 2,2
    • Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches.
  4. Nokia 6102i Outside Display Screen Replacement, Unplug and Remove Circuit Board: 步骤 4 中的图像 1,2 Nokia 6102i Outside Display Screen Replacement, Unplug and Remove Circuit Board: 步骤 4 中的图像 2,2
    • Pull out the circuit board, which will remove it completely from the case
  5. Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: 步骤 5 中的图像 1,3 Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: 步骤 5 中的图像 2,3 Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: 步骤 5 中的图像 3,3
    • If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen.
  6. Nokia 6102i Outside Display Screen Replacement, Disconnect Interior Display Screen from circuit board.: 步骤 6 中的图像 1,2 Nokia 6102i Outside Display Screen Replacement, Disconnect Interior Display Screen from circuit board.: 步骤 6 中的图像 2,2
    • Be gentle when pulling off the display screen. If pulled too hard, the orange connecting ribbon will rip.
    • Lift off the display screen and disconnect it from the circuit board.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 23-78, Johann Spring 2010 Cal Poly, Team 23-78, Johann Spring 2010 的会员
CPSU-JOHANN-S10S23G78
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 2,729
