跳转到主内容
加入维修社区 - 创建账户
Nokia 6086 Vibrator Replacement
你所需要的
    1. Nokia 6086 Vibrator Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn off the phone.
      • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
      • Position the phone so that the back side is in view.
      询问修复机器人
      添加评论
    2. Nokia 6086 Vibrator Replacement: 步骤 2 中的图像 1,3 Nokia 6086 Vibrator Replacement: 步骤 2 中的图像 2,3 Nokia 6086 Vibrator Replacement: 步骤 2 中的图像 3,3
      • Remove the back battery cover.
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      询问修复机器人
      添加评论
    3. Nokia 6086 Vibrator Replacement: 步骤 3 中的图像 1,3 Nokia 6086 Vibrator Replacement: 步骤 3 中的图像 2,3 Nokia 6086 Vibrator Replacement: 步骤 3 中的图像 3,3
      • Insert the iPod opening tool between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • The battery lifts out of the phone fast and easily.
      • Carefully lift the battery out of the phone.
      询问修复机器人
      添加评论
    1. Nokia 6086 Vibrator Replacement, Upper Back Cover: 步骤 4 中的图像 1,1
      • Turn the phone so that the back of the phone is facing forward.
      • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
      • In this picture, the upper cover has already been removed.
      询问修复机器人
      添加评论
    2. Nokia 6086 Vibrator Replacement: 步骤 5 中的图像 1,2 Nokia 6086 Vibrator Replacement: 步骤 5 中的图像 2,2
      • Place the iPod opening tool under the tabs near the top of the phone.
      • Slide the iPod Opening Tool upwards.
      • This will pop the tabs and release the upper part of the phone.
      • Repeat for the left and the right sides.
      询问修复机器人
      添加评论
    3. Nokia 6086 Vibrator Replacement: 步骤 6 中的图像 1,2 Nokia 6086 Vibrator Replacement: 步骤 6 中的图像 2,2
      • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
      • Lift the iPod opening tool to pop open the clips.
      • This will release the upper back cover of the phone.
      询问修复机器人
      添加评论
    4. Nokia 6086 Vibrator Replacement: 步骤 7 中的图像 1,3 Nokia 6086 Vibrator Replacement: 步骤 7 中的图像 2,3 Nokia 6086 Vibrator Replacement: 步骤 7 中的图像 3,3
      • Push upward on the top back cover using two thumbs.
      • This will remove the top back cover from the phone.
      询问修复机器人
      添加评论
    1. Nokia 6086 Vibrator Replacement, Base of The Phone: 步骤 8 中的图像 1,2 Nokia 6086 Vibrator Replacement, Base of The Phone: 步骤 8 中的图像 2,2
      • Locate the four screws.
      • Remove the screws using a T6 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Nokia 6086 Vibrator Replacement: 步骤 9 中的图像 1,2 Nokia 6086 Vibrator Replacement: 步骤 9 中的图像 2,2
      • Turn the phone over.
      • Gently pull apart the phone.
      • Start at the bottom of the phone and pull outward.
      • There are plastic catches on the middle of each side. These should pop free as you pull.
      • Be careful, the phone will separate into two sections.
      询问修复机器人
      添加评论
    3. Nokia 6086 Vibrator Replacement: 步骤 10 中的图像 1,2 Nokia 6086 Vibrator Replacement: 步骤 10 中的图像 2,2
      • The phone should now be in two different sections.
      • 1) The logic board and the back cover
      • 2) The keypad and the rest of the phone
      询问修复机器人
      添加评论
    1. Nokia 6086 Vibrator Replacement, Vibrator: 步骤 11 中的图像 1,3 Nokia 6086 Vibrator Replacement, Vibrator: 步骤 11 中的图像 2,3 Nokia 6086 Vibrator Replacement, Vibrator: 步骤 11 中的图像 3,3
      • Remove the logic board from the bottom casing.
      询问修复机器人
      添加评论
    2. Nokia 6086 Vibrator Replacement: 步骤 12 中的图像 1,1
      • The logic board should be fully detached from the phone.
      • The turquoise colored vibrator should now be visible.
      询问修复机器人
      添加评论
    3. Nokia 6086 Vibrator Replacement: 步骤 13 中的图像 1,2 Nokia 6086 Vibrator Replacement: 步骤 13 中的图像 2,2
      在这个步骤中使用的工具:
      • Place the tweezers at the base of the vibrator.
      • Squeeze the tweezers while simultaneously lifting them up to remove the vibrator.
      询问修复机器人
      添加评论
    4. Nokia 6086 Vibrator Replacement: 步骤 14 中的图像 1,1
      • The vibrator should be detached from the phone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Caitlin Rahm
于04/15/10注册
78 声望
创作了4篇指南
团队
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G30
4 名成员
创作了99篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 1,487
