跳转到主内容
Nokia 6086 Battery Replacement
Andrea
Andrea6 其他贡献者
最后更新于 January 6, 2025
5分钟
中等
This guide is a step by step process to remove the battery of the phone. It is a preliminary step to many installation guides.
你所需要的
工具
  1. Nokia 6086 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Battery Replacement: 步骤 2 中的图像 1,3 Nokia 6086 Battery Replacement: 步骤 2 中的图像 2,3 Nokia 6086 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Battery Replacement: 步骤 3 中的图像 1,3 Nokia 6086 Battery Replacement: 步骤 3 中的图像 2,3 Nokia 6086 Battery Replacement: 步骤 3 中的图像 3,3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
结论
Andrea
于04/15/10注册
70 声望
创作了5篇指南
团队
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G30
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 3,880
