跳转到主内容
Nokia 6085h Microphone Replacement
Andrew
Andrew9 其他贡献者
最后更新于 January 10, 2025
5 - 10 分钟
中等
需要更好的图片
不一致的图片
The microphone is an essential component of the Nokia 6085h as it is responsible for the transmission of the audio. Malfunction of the microphone may require replacement or repair, but first it needs to be located.
Follow this guide to help locate the microphone for removal or/and repair. Please be gentle with the tools as you remove each component of the Nokia 6085h.
你所需要的
工具
查看更多...
  1. Nokia 6085h Microphone Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the phone's battery.
  3. Nokia 6085h Microphone Replacement, Motherboard: 步骤 3 中的图像 1,2 Nokia 6085h Microphone Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
  4. Nokia 6085h Microphone Replacement: 步骤 4 中的图像 1,1
    • Gently pull off the hinge cap from the top of the phone by hand.
  5. Nokia 6085h Microphone Replacement: 步骤 5 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the four 7.6 mm screws at the corners of the battery compartment.
  6. Nokia 6085h Microphone Replacement: 步骤 6 中的图像 1,2 Nokia 6085h Microphone Replacement: 步骤 6 中的图像 2,2
    • Open the phone and turn it on its side. You will see a seam around the Nokia’s side.
    • Use the iFixit opening tool to run along this seam to pop the clips holding the casing to the frame.
  7. Nokia 6085h Microphone Replacement: 步骤 7 中的图像 1,1
    • Use your hand to gently pull off the back panel from the bottom half of the phone.
  8. Nokia 6085h Microphone Replacement: 步骤 8 中的图像 1,1
    • Close the phone and place it on a flat surface.
    • Use the plastic opening tool or your finger to lift up the motherboard from the bottom casing.
    • Be careful when pulling up the board; there is still a ribbon cable attached to the back of the board.
  9. Nokia 6085h Microphone Replacement: 步骤 9 中的图像 1,1
    • Find the underside of the motherboard and locate the ribbon cable that attaches the board to the rest of the phone. Use the plastic opening tool to slowly detach the ribbon cable connector, then pull the motherboard away from the frame.
  10. Nokia 6085h Microphone Replacement, Keypad: 步骤 10 中的图像 1,1
    • Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
  11. Nokia 6085h Microphone Replacement, Microphone: 步骤 11 中的图像 1,1
    • Locate the small speaker module on the back of the separated battery compartment in the lower left hand corner.
  12. Nokia 6085h Microphone Replacement: 步骤 12 中的图像 1,1
    • Use the plastic opening tool to pry out the microphone from the bottom of the compartment.
结论
Andrew
于10/04/10注册
397 声望
创作了4篇指南
团队
Cal Poly, Team 4-46, Amido Fall 2010 Cal Poly, Team 4-46, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G46
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 383
