跳转到主内容
Nokia 3360 Cover Plate Replacement
Kirk Gonzalez
Kirk Gonzalez4 其他贡献者
最后更新于 February 19, 2025
1分钟
非常容易
需要更好的图片
This guide shows how remove and replace a damaged cover plate.
  1. Nokia 3360 Cover Plate Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Cover Plate Replacement: 步骤 2 中的图像 1,2 Nokia 3360 Cover Plate Replacement: 步骤 2 中的图像 2,2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Cover Plate Replacement: 步骤 3 中的图像 1,2 Nokia 3360 Cover Plate Replacement: 步骤 3 中的图像 2,2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Cover Plate Replacement, Cover Plate: 步骤 4 中的图像 1,2 Nokia 3360 Cover Plate Replacement, Cover Plate: 步骤 4 中的图像 2,2
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
结论
2等其他人完成本指南。
Kirk Gonzalez
于01/22/10注册
223 声望
创作了3篇指南
团队
Cal Poly, Team 8-39, Regan Winter 2010 Cal Poly, Team 8-39, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G39
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 17
总计 2,745
