跳转到主内容
Nokia 3310 3G Speaker Replacement
Aaron LeBlanc
Aaron LeBlanc3 其他贡献者
最后更新于 April 5, 2023
10 - 20 分钟
困难
If your speaker is no longer producing sound, it may be necessary to replace the speaker altogether. This guide shows a step by step guide to fully access the speaker.
你所需要的
工具
查看更多...
  1. Nokia 3310 3G Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 3310 3G Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Speaker Replacement: 步骤 2 中的图像 1,2 Nokia 3310 3G Speaker Replacement: 步骤 2 中的图像 2,2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Speaker Replacement, Frame: 步骤 3 中的图像 1,3 Nokia 3310 3G Speaker Replacement, Frame: 步骤 3 中的图像 2,3 Nokia 3310 3G Speaker Replacement, Frame: 步骤 3 中的图像 3,3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Speaker Replacement, Motherboard: 步骤 4 中的图像 1,3 Nokia 3310 3G Speaker Replacement, Motherboard: 步骤 4 中的图像 2,3 Nokia 3310 3G Speaker Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Nokia 3310 3G Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
    • Use the metal spudger to leverage out the speaker.
    • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
结论
Aaron LeBlanc
于10/24/18注册
735 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G3
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 16
总计 1,645
