跳转到主内容
Nokia 3310 3G Camera Replacement
Taylor Lyford
Taylor Lyford3 其他贡献者
最后更新于 April 5, 2023
15分钟
中等
In the event of a drop, the rear camera on the Nokia 3310 3G can be damaged. This guide will show the steps necessary to replace it.
你所需要的
工具
查看更多...
  1. Nokia 3310 3G Camera Replacement, Battery: 步骤 1 中的图像 1,2 Nokia 3310 3G Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Camera Replacement: 步骤 2 中的图像 1,2 Nokia 3310 3G Camera Replacement: 步骤 2 中的图像 2,2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Camera Replacement, Frame: 步骤 3 中的图像 1,3 Nokia 3310 3G Camera Replacement, Frame: 步骤 3 中的图像 2,3 Nokia 3310 3G Camera Replacement, Frame: 步骤 3 中的图像 3,3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Camera Replacement, Camera: 步骤 4 中的图像 1,2 Nokia 3310 3G Camera Replacement, Camera: 步骤 4 中的图像 2,2
    • Using the pointed metal spudger from the metal spudger set, insert the tool underneath the small snap clip, and disconnect it by lifting it up.
  5. Nokia 3310 3G Camera Replacement: 步骤 5 中的图像 1,2 Nokia 3310 3G Camera Replacement: 步骤 5 中的图像 2,2
    • The camera is held in with double sided and foam. Using the spudger, lift up on the camera to remove it from the motherboard of the phone.
结论
3等其他人完成本指南。
Taylor Lyford
于10/24/18注册
714 声望
创作了3篇指南
团队
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G3
3 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 941
