跳转到主内容
Nokia 3120b Battery Installation Replacement
Justin Emerson
Justin Emerson6 其他贡献者
最后更新于 September 9, 2017
2分钟
非常容易
This guide directs the user to remove the battery of the Nokia 3120b. The battery is easily accessible as it is located directly under the back cover plate of the phone. A new battery can be installed the same way an old one is removed.
你所需要的
工具
  • Probe and Pick Set
    Probe and Pick Set
  1. Nokia 3120b Battery Installation Replacement, Battery Installation: 步骤 1 中的图像 1,3 Nokia 3120b Battery Installation Replacement, Battery Installation: 步骤 1 中的图像 2,3 Nokia 3120b Battery Installation Replacement, Battery Installation: 步骤 1 中的图像 3,3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120b Battery Installation Replacement: 步骤 2 中的图像 1,1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
结论
另外一个人完成了本指南。
Justin Emerson
于03/11/13注册
166 声望
创作了2篇指南
团队
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G2
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 658
