跳转到主内容
加入维修社区 - 创建账户
Nokia 2630b Back Case Replacement
你所需要的
  1. Nokia 2630b Back Case Replacement, Battery Case: 步骤 1 中的图像 1,2 Nokia 2630b Back Case Replacement, Battery Case: 步骤 1 中的图像 2,2
    • Press and the release button on both sides of the battery cover. While holding down the release buttons pull the battery cover away from the phone
  2. Nokia 2630b Back Case Replacement: 步骤 2 中的图像 1,1
    • Pull out the battery by holding the top of the battery and tilting out.
  3. Nokia 2630b Back Case Replacement, Screen / Front Case: 步骤 3 中的图像 1,1
    • Remove the two screws on either side of the battery case using a T5 Torx screwdriver.
  4. Nokia 2630b Back Case Replacement: 步骤 4 中的图像 1,3 Nokia 2630b Back Case Replacement: 步骤 4 中的图像 2,3 Nokia 2630b Back Case Replacement: 步骤 4 中的图像 3,3
    • Separate the front case from the back case using the iPod opener.
    • The keypad is a loose piece and may fall out.
  5. Nokia 2630b Back Case Replacement: 步骤 5 中的图像 1,1
    • Remove screws using the T5 Torx screwdriver to release the computer chip from the case.
  6. Nokia 2630b Back Case Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the black frame off the screen with your fingers.
  7. Nokia 2630b Back Case Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the computer chip and screen out of the black case with your fingers.
  8. Nokia 2630b Back Case Replacement: 步骤 8 中的图像 1,2 Nokia 2630b Back Case Replacement: 步骤 8 中的图像 2,2
    • The screen is attached to the motherboard by an orange ribbon.
    • Carefully detach the ribbon from the motherboard using your fingers.
  9. Nokia 2630b Back Case Replacement: 步骤 9 中的图像 1,1
    • Reattach new screen by connecting the orange ribbon to the computer chip.
  10. Nokia 2630b Back Case Replacement: 步骤 10 中的图像 1,2 Nokia 2630b Back Case Replacement: 步骤 10 中的图像 2,2
    • Place computer chip and screen back into black case.
  11. Nokia 2630b Back Case Replacement: 步骤 11 中的图像 1,1
    • Place black frame back over screen.
  12. Nokia 2630b Back Case Replacement: 步骤 12 中的图像 1,2 Nokia 2630b Back Case Replacement: 步骤 12 中的图像 2,2
    • Carefully place keypad back in place.
  13. Nokia 2630b Back Case Replacement: 步骤 13 中的图像 1,2 Nokia 2630b Back Case Replacement: 步骤 13 中的图像 2,2
    • Snap the front case back in place with the bottom case with your fingers.
  14. Nokia 2630b Back Case Replacement: 步骤 14 中的图像 1,1
    • Reassemble screws with microscrewdriver.
  15. Nokia 2630b Back Case Replacement: 步骤 15 中的图像 1,1
    • Slide battery back into place.
  16. Nokia 2630b Back Case Replacement: 步骤 16 中的图像 1,1
    • Snap battery cover back into place.
  17. Nokia 2630b Back Case Replacement, Back Case: 步骤 17 中的图像 1,2 Nokia 2630b Back Case Replacement, Back Case: 步骤 17 中的图像 2,2
    • Locate the four screws that secure the back case to the rest of the phone.
    • Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
  18. Nokia 2630b Back Case Replacement: 步骤 18 中的图像 1,3 Nokia 2630b Back Case Replacement: 步骤 18 中的图像 2,3 Nokia 2630b Back Case Replacement: 步骤 18 中的图像 3,3
    • DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone.
    • Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eric
于04/07/11注册
57 声望
创作了4篇指南
团队
Cal Poly, Team 9-61, Walters Spring 2011 Cal Poly, Team 9-61, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G61
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 30
总计 2,163
