跳转到主内容
Nokia 1100b RH-36 Front Cover Replacement
JSwan
JSwan4 其他贡献者
最后更新于 January 20, 2025
2分钟
简单
特色学生指南
This will guide you through removing the front cover from the main body of your Nokia 1100b RH-36.
  1. Nokia 1100b RH-36 Front Cover Replacement, Front Cover: 步骤 1 中的图像 1,2 Nokia 1100b RH-36 Front Cover Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
结论
3等其他人完成本指南。
JSwan
于04/12/13注册
781 声望
创作了6篇指南
团队
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G43
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 1,023
