跳转到主内容
加入维修社区 - 创建账户
Nobis NB07 Microphone Replacement
你所需要的
    1. Nobis NB07 Microphone Replacement, Opening the case: 步骤 1 中的图像 1,1
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      询问修复机器人
      添加评论
    2. Nobis NB07 Microphone Replacement: 步骤 2 中的图像 1,3 Nobis NB07 Microphone Replacement: 步骤 2 中的图像 2,3 Nobis NB07 Microphone Replacement: 步骤 2 中的图像 3,3
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      询问修复机器人
      添加评论
    3. Nobis NB07 Microphone Replacement, Replacing the battery: 步骤 3 中的图像 1,3 Nobis NB07 Microphone Replacement, Replacing the battery: 步骤 3 中的图像 2,3 Nobis NB07 Microphone Replacement, Replacing the battery: 步骤 3 中的图像 3,3
      • Remove the tape holding the battery in place.
      询问修复机器人
      添加评论
    4. Nobis NB07 Microphone Replacement: 步骤 4 中的图像 1,3 Nobis NB07 Microphone Replacement: 步骤 4 中的图像 2,3 Nobis NB07 Microphone Replacement: 步骤 4 中的图像 3,3
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      询问修复机器人
      添加评论
    5. Nobis NB07 Microphone Replacement: 步骤 5 中的图像 1,1
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      询问修复机器人
      添加评论
    6. Nobis NB07 Microphone Replacement: 步骤 6 中的图像 1,2 Nobis NB07 Microphone Replacement: 步骤 6 中的图像 2,2
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      询问修复机器人
      添加评论
    1. Nobis NB07 Microphone Replacement, Removing the cameras: 步骤 7 中的图像 1,3 Nobis NB07 Microphone Replacement, Removing the cameras: 步骤 7 中的图像 2,3 Nobis NB07 Microphone Replacement, Removing the cameras: 步骤 7 中的图像 3,3
      • Remove the black tape covering the cameras power cable.
      询问修复机器人
      添加评论
    2. Nobis NB07 Microphone Replacement: 步骤 8 中的图像 1,2 Nobis NB07 Microphone Replacement: 步骤 8 中的图像 2,2
      • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
      询问修复机器人
      添加评论
    3. Nobis NB07 Microphone Replacement: 步骤 9 中的图像 1,3 Nobis NB07 Microphone Replacement: 步骤 9 中的图像 2,3 Nobis NB07 Microphone Replacement: 步骤 9 中的图像 3,3
      在这个步骤中使用的工具:
      • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
      • Using tweezers, carefully grab the front camera and twist slowly.
      • The camera should release easily, do not twist too hard.
      • You can now remove the cameras.
      询问修复机器人
      添加评论
    1. Nobis NB07 Microphone Replacement, Removing the microphone: 步骤 10 中的图像 1,1
      • Locate the microphone's cables in front of the cameras' ZIF connector.
      询问修复机器人
      添加评论
    2. Nobis NB07 Microphone Replacement: 步骤 11 中的图像 1,1
      询问修复机器人
      添加评论
    3. Nobis NB07 Microphone Replacement: 步骤 12 中的图像 1,2 Nobis NB07 Microphone Replacement: 步骤 12 中的图像 2,2
      在这个步骤中使用的工具:
      • Use the pointy end of the tweezers to retrieve the microphone from its socket.
      • You can now remove the microphone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 的会员
USFT-BROWN-W15S5G5
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 501
