跳转到主内容
加入维修社区 - 创建账户
Nintendo WaveBird Wireless Controller Motherboard Replacement
你所需要的
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: 步骤 1 中的图像 1,2 Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: 步骤 1 中的图像 2,2
      • Pull down on the battery cover release lever and pull back to remove the cover.
      询问修复机器人
      添加评论
    2. Nintendo WaveBird Wireless Controller Motherboard Replacement: 步骤 2 中的图像 1,1
      • Remove both batteries from the device.
      询问修复机器人
      添加评论
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: 步骤 3 中的图像 1,2 Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: 步骤 3 中的图像 2,2
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
      询问修复机器人
      添加评论
    2. Nintendo WaveBird Wireless Controller Motherboard Replacement: 步骤 4 中的图像 1,2 Nintendo WaveBird Wireless Controller Motherboard Replacement: 步骤 4 中的图像 2,2
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
      询问修复机器人
      添加评论
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: 步骤 5 中的图像 1,3 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: 步骤 5 中的图像 2,3 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to remove the buttons.
      • It may be easier to remove the A button off of the pad by lifting it with your fingers.
      • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
      询问修复机器人
      添加评论
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers remove the three grey button pads from the motherboard.
      询问修复机器人
      添加评论
    2. Nintendo WaveBird Wireless Controller Motherboard Replacement: 步骤 7 中的图像 1,1
      • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
      • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
团队
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G40
4 名成员
创作了114篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 49
过去 30 天: 116
总计 9,794
