跳转到主内容
加入维修社区 - 创建账户
Nintendo WaveBird Wireless Controller C-Stick Replacement
你所需要的
    1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: 步骤 1 中的图像 1,2 Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: 步骤 1 中的图像 2,2
      • Pull down on the battery cover release lever and pull back to remove the cover.
      询问修复机器人
      添加评论
    2. Nintendo WaveBird Wireless Controller C-Stick Replacement: 步骤 2 中的图像 1,1
      • Remove both batteries from the device.
      询问修复机器人
      添加评论
    1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: 步骤 3 中的图像 1,2 Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: 步骤 3 中的图像 2,2
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
      询问修复机器人
      添加评论
    2. Nintendo WaveBird Wireless Controller C-Stick Replacement: 步骤 4 中的图像 1,2 Nintendo WaveBird Wireless Controller C-Stick Replacement: 步骤 4 中的图像 2,2
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
      询问修复机器人
      添加评论
    1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 步骤 5 中的图像 1,3 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 步骤 5 中的图像 2,3 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to remove the buttons.
      • It may be easier to remove the A button off of the pad by lifting it with your fingers.
      • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
      询问修复机器人
      添加评论
    1. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: 步骤 6 中的图像 1,2 Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: 步骤 6 中的图像 2,2
      • Potential for device damage: Rough handling of the C-stick could cause the daughterboard to break off of the motherboard.
      • Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
      • Pull off the yellow C-Stick cover.
      • During reassembly, make sure the slots inside the C-Stick cover line up with the motherboard so it can fit back together.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G40
4 名成员
创作了114篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 44
总计 3,055
