跳转到主内容
Nintendo Switch Pro Controller Battery Replacement
你所需要的
  1. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: 步骤 1 中的图像 1,1
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: 步骤 2 中的图像 1,3 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: 步骤 2 中的图像 2,3 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: 步骤 2 中的图像 3,3
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: 步骤 3 中的图像 1,1
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: 步骤 4 中的图像 1,3 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: 步骤 4 中的图像 2,3 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: 步骤 4 中的图像 3,3
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Battery Replacement, Remove the clear plastic cover: 步骤 5 中的图像 1,1
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Battery Replacement, Remove the battery: 步骤 6 中的图像 1,3 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: 步骤 6 中的图像 2,3 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: 步骤 6 中的图像 3,3
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
43等其他人完成本指南。
Daniel Tagalog
于10/10/19注册
2,042 声望
创作了3篇指南
团队
Cal Poly, Team S11-G2, Regan Fall 2019 Cal Poly, Team S11-G2, Regan Fall 2019 的会员
CPSU-REGAN-F19S11G2
5 名成员
创作了45篇指南
14指南评论
now what after taking the battery out
Seani M - 回复
Install the replacement battery and follow the steps in reverse order…
frzno72 -
easy peasy only have to recycle battery
Dan Carroll - 回复
Where can I buy genuine ctr-003 batteries in germany/europe?
smol_tsukiko - 回复
You can buy them directly in the iFixit Europe or in your case in the Germany store.
Henrynaja -
添加评论
浏览统计数据:
过去 24 小时: 51
过去 7 天: 318
过去 30 天: 1,252
总计 90,381
