跳转到主内容
Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement
你所需要的
  1. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: 步骤 1 中的图像 3,3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the Joy Con controllers: 步骤 2 中的图像 3,3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the top screw: 步骤 3 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the top screw: 步骤 3 中的图像 2,2
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the bottom screws: 步骤 4 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the bottom screws: 步骤 4 中的图像 2,2
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the right screw: 步骤 5 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the right screw: 步骤 5 中的图像 2,2
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the left screw: 步骤 6 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the left screw: 步骤 6 中的图像 2,2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Open the kickstand: 步骤 7 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Open the kickstand: 步骤 7 中的图像 2,2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the back-side screws: 步骤 8 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the back-side screws: 步骤 8 中的图像 2,2
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the rear case: 步骤 9 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the rear case: 步骤 9 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the rear case: 步骤 9 中的图像 3,3
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the shield plate's tape: 步骤 10 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the shield plate's tape: 步骤 10 中的图像 2,2
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 11 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 11 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the primary Wi-Fi antenna: 步骤 12 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the primary Wi-Fi antenna: 步骤 12 中的图像 2,2
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Reroute the primary antenna's coaxial cable: 步骤 13 中的图像 3,3
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the primary Wi-Fi antenna: 步骤 14 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the primary Wi-Fi antenna: 步骤 14 中的图像 2,2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the primary Wi-Fi antenna: 步骤 15 中的图像 3,3
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 16 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 16 中的图像 2,2
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the secondary Wi-Fi antenna: 步骤 17 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the secondary Wi-Fi antenna: 步骤 17 中的图像 2,2
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 步骤 18 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: 步骤 18 中的图像 2,2
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the secondary Wi-Fi antenna: 步骤 19 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the secondary Wi-Fi antenna: 步骤 19 中的图像 2,2
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the secondary Wi-Fi antenna: 步骤 20 中的图像 3,3
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 21 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 21 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 21 中的图像 3,3
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the shield plate: 步骤 22 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the shield plate: 步骤 22 中的图像 2,2
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 23 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 23 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Thermal Putty
    $9.95
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
  24. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the battery: 步骤 24 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the battery: 步骤 24 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery.
  25. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the tape: 步骤 25 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the tape: 步骤 25 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the tape: 步骤 25 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
  26. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the daughterboard: 步骤 26 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the daughterboard: 步骤 26 中的图像 2,2
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
  27. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the daughterboard: 步骤 27 中的图像 1,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the daughterboard: 步骤 27 中的图像 2,3 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the daughterboard: 步骤 27 中的图像 3,3
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  28. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: 步骤 28 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: 步骤 28 中的图像 2,2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the right Joy-Con sensor rail's ZIF connector.
  29. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 29 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement: 步骤 29 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to pull the right Joy-Con sensor rail's cable straight out of its connector on the motherboard.
  30. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the right Joy-Con sensor rail: 步骤 30 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Unfasten the right Joy-Con sensor rail: 步骤 30 中的图像 2,2
    • Use a Phillips driver to remove the two 3.8 mm screws securing the left Joy-Con sensor rail to the frame.
  31. Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the right Joy-Con sensor rail: 步骤 31 中的图像 1,2 Nintendo Switch OLED Model Right Joy-Con Sensor Rail Replacement, Remove the right Joy-Con sensor rail: 步骤 31 中的图像 2,2
    • Remove the right Joy-Con sensor rail.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
13等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
214,548 声望
创作了1,044篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,764篇指南
1指南评论
Thank you for the staps it helpt me replacing the rails. Later i saw a video on youtube that they removed the shield plate with the wifi antennas and tape stil on it. So removing this seems unnecessary...
Alva22 - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 134
过去 30 天: 486
总计 13,712
