简介
根据本指南的操作来更换Switch的左侧Joy-Con手柄滑轨。
Switch使用日本工业标准(JIS)螺丝,但是如果您如果实在需要,您也可以用标准十字螺丝刀进行维修. 请注意、避免螺丝滑丝。 iFixit所销售的螺丝套件可以兼容日本工业标准螺丝.
注1:当拆除屏蔽板时,板子和散热片之间的导热硅脂也需要更换.一般市面的硅脂并不能有效填满大型缝隙.与原装硅脂最接近的是K5 Pro viscous 导热硅脂.
注2:本指南和iFixit所销售的零配件,同时兼容原装初代2017款任天堂switch(版本号HAC-001)和2019款新版本(版本号HAC-001(-01))
你所需要的
使用 JIS000 螺丝刀,或者 iFixIt PH000 螺丝刀取下用于固定后面板的螺丝:
一颗在主机顶部的散热器出口旁,长度为2.5毫米的螺丝
两颗在主机底部的充电接口两侧,长度为2.5毫米的螺丝
对比你换上的器件和原装件,你在安装前可能需要保留,转移部分原有部件或者移除新件的粘性背板.
如需重新安装设备,倒序执行本指南即可.
请将电子垃圾送到R2或e- steward认证的回收商。
维修遇到问题? 请见 基础故障排除, 或至 任天堂Switch 社区 寻求帮助.
如需重新安装设备,倒序执行本指南即可.
59等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7条评论
If this was a neon Switch, this would be the rail that gets attached with the blue or the red joy con?
it would be the Blue joy con
I completed this guide, but the left joy con is still not being detected after the sensor rail was replaced with a sensor rail purchased on this site. The joy con in question will attach and sync with another console, so that leads me to believe it is a fault with the switch console itself. Is there something else that I can replace that would fix this issue?
Depending on where you get your replacement rail, it may not have the silver on the ribbon cable. No worries, as I did this repair 3 months ago (Jan) and had no issues at all.
To get the ribbon cable in place, I recommend first getting the battery wires out of the way, then slightly bending it and sliding it under that section of the Motherboard. If you do it right, the end of the ribbon cable will pop up and that can be slid into place. Took some fiddling but I eventually got it to work!
No matter what, never crease your ribbon cables!
