跳转到主内容
Nintendo Game Boy Advance SP Speaker Replacement
Chase
Chase2 其他贡献者
最后更新于 July 26, 2024
15分钟
简单
社区贡献指南
你所需要的
  1. Nintendo Game Boy Advance SP Speaker Replacement, Removing the back plate: 步骤 1 中的图像 1,3 Nintendo Game Boy Advance SP Speaker Replacement, Removing the back plate: 步骤 1 中的图像 2,3 Nintendo Game Boy Advance SP Speaker Replacement, Removing the back plate: 步骤 1 中的图像 3,3
    • Start by removing the battery cover and take out the battery.
    • Remove the 6 tri point screws on the back plating.
    • The back plate should lift right off.
    • Also remove the 3 phillip screws on the mother board.
  2. Nintendo Game Boy Advance SP Speaker Replacement, Pull up the mother board: 步骤 2 中的图像 1,1
    • Pull up the mother board from the bottom, opposite the ribbon cable. Try not to put any stress on the ribbon cable.
  3. Nintendo Game Boy Advance SP Speaker Replacement, Replacing the speaker and re assembly: 步骤 3 中的图像 1,1
    • The speaker makes contact to the mother board by two pads, no soldering required. Just place the new speaker in it's slot along with the rest of the buttons.
    • To re assemble put back down the mother board to it's original position and follow the steps in reverse. I would recommend doing a dry test by just holding the console together and testing it out before you screw anything back in.
    • A few things for re assembly , make sure the power switch remains in the back casing as it can easily fall out, and make sure it is set to off. Do not lose the square nut on the back casing as it is not replaceable.
结论
3等其他人完成本指南。
Chase
于01/19/22注册
163 声望
撰写一个指南
1指南评论
Didn't need to replace it but needed to re-seat it and bend its pins up enough to make consistent contact since audio was cutting out here and there. This was super helpful!
bilowik - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 91
总计 849
