简介
转到步骤 1 ↓Follow this guide to replace the speaker in your Nintendo Game Boy Advance SP.
If you hear distorted audio, crackling sounds, or no sound at all from your Game Boy, you may need to replace the speaker.
The Game Boy Advance SP uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
你所需要的
工具
Slide the power switch to the OFF position and unplug any cables.
If you have a game cartridge in, remove it.
Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
Four 6.3 mm‑long recessed screws
Two 4.6 mm‑long screws
Use your fingers to lift and remove the power switch cover.
Use your fingers to put the power switch cover (notched side up) into place so the cutout goes around the actual switch.
Gently slide the cover back and forth to make sure it's positioned properly and moving the switch.
Use a JIS 00 screwdriver to remove the three 4.1 mm‑long screws securing the motherboard.
Place a sturdy object such as a stack of books or tool case along the edge of your Game Boy with the hinges.
Use your fingers to gently flip the motherboard over the hinges and prop it up.
Use the point of a spudger or a clean fingernail to lift the speaker until you can grip it with your fingers.
Grip the speaker with your fingers and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
16等其他人完成本指南。
