跳转到主内容
加入维修社区 - 创建账户
Nintendo Entertainment System Game Cartridge Tray Replacement
你所需要的
  1. Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: 步骤 1 中的图像 1,2 Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: 步骤 1 中的图像 2,2
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
    添加评论
  2. Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 2 中的图像 1,2 Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
    询问修复机器人
    添加评论
  3. Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 3 中的图像 1,3 Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 3 中的图像 2,3 Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 3 中的图像 3,3
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
    添加评论
  4. Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 4 中的图像 1,2 Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 4 中的图像 2,2
    • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
    • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
    添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
团队
Cal Poly, Team 14-40, Forte Fall 2010 Cal Poly, Team 14-40, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G40
4 名成员
创作了28篇指南
1指南评论
I’m looking for a part that latches the tray into place it’s light blue in colour with a groove in it
Tony - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 126
总计 18,099
