跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi Top LCD Screen Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
    1. 注意:步骤 1-2 源自标记为进行中的 指南
      Nintendo DSi Top LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
      询问修复机器人
      添加评论
    2. Nintendo DSi Top LCD Screen Replacement: 步骤 2 中的图像 1,1
      • L Button.
      • Top of the battery pack.
      • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
      添加评论
    1. 注意:步骤 3-4 源自标记为进行中的 指南
      Nintendo DSi Top LCD Screen Replacement, Motherboard: 步骤 3 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement, Motherboard: 步骤 3 中的图像 2,2
      • Remove 4 Phillips screws from the board.
      • Lift the main board from the bottom end and flip it over to reveal the last connector.
      • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
      询问修复机器人
      添加评论
    2. Nintendo DSi Top LCD Screen Replacement: 步骤 4 中的图像 1,1
      • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
      • The motherboard should now be free from the rest of the device.
      询问修复机器人
      添加评论
    1. Nintendo DSi Top LCD Screen Replacement, Bottom Case: 步骤 5 中的图像 1,1
      • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
      • A/B/X/Y button assembly
      • Select/Start button assembly
      • D-pad
      • Power button
      询问修复机器人
      添加评论
    2. Nintendo DSi Top LCD Screen Replacement: 步骤 6 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement: 步骤 6 中的图像 2,2
      • Remove the plastic buttons and keep them in a safe place.
      • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
      询问修复机器人
      添加评论
    3. Nintendo DSi Top LCD Screen Replacement: 步骤 7 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement: 步骤 7 中的图像 2,2
      • Flip the case open, and push the lower screen assembly out of the frame.
      询问修复机器人
      添加评论
    1. Nintendo DSi Top LCD Screen Replacement, Top LCD Screen: 步骤 8 中的图像 1,1
      • To make the repair easier, we recommend removing the bottom LCD screen prior to replacing the top LCD screen.
      • Using a spudger, or similar tool, pry out the 4 square screw covers.
      询问修复机器人
      添加评论
    2. Nintendo DSi Top LCD Screen Replacement: 步骤 9 中的图像 1,1
      • Remove 4 Phillips screws with a #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    3. Nintendo DSi Top LCD Screen Replacement: 步骤 10 中的图像 1,1
      • Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
      • With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
      询问修复机器人
      添加评论
    4. Nintendo DSi Top LCD Screen Replacement: 步骤 11 中的图像 1,1
      • Remove the antenna from the bottom left of the device.
      • Remove the microphone from the top of the frame.
      询问修复机器人
      添加评论
    5. Nintendo DSi Top LCD Screen Replacement: 步骤 12 中的图像 1,1
      • Use a spudger to pry the camera out of its place.
      询问修复机器人
      添加评论
    6. Nintendo DSi Top LCD Screen Replacement: 步骤 13 中的图像 1,1
      • Cables for the components in the upper half of the device run through the hinge, which must be carefully disassembled before continuing.
      • Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
      询问修复机器人
      添加评论
    7. Nintendo DSi Top LCD Screen Replacement: 步骤 14 中的图像 1,1
      • On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
      • Push the sliding shaft completely through the hinge until it stops and the hinge is released.
      询问修复机器人
      添加评论
    8. Nintendo DSi Top LCD Screen Replacement: 步骤 15 中的图像 1,1
      • The right side of bottom case should separate from the top case when you remove the sliding shaft.
      • Do not pull up too far or the wire hinge may be damaged.
      • Slide the top case to the right to separate the joint.
      • Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
      询问修复机器人
      添加评论
    9. Nintendo DSi Top LCD Screen Replacement: 步骤 16 中的图像 1,2 Nintendo DSi Top LCD Screen Replacement: 步骤 16 中的图像 2,2
      • The speakers are soldered to the ribbon cable attached to the upper LCD, so they must be removed at the same time as the LCD.
      • Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
      询问修复机器人
      添加评论
    10. Nintendo DSi Top LCD Screen Replacement: 步骤 17 中的图像 1,1
      • To remove the speakers, use a spudger or a similar tool to gently pry them off.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
rjcamero
于11/05/09注册
56 声望
创作了3篇指南
团队
Cal Poly, Team 6-1, Maness Fall 2009 Cal Poly, Team 6-1, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G1
5 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 125
过去 30 天: 610
总计 44,125
