跳转到主内容
加入维修社区 - 创建账户
Nintendo DS Lite Lower Screen Replacement
你所需要的
  1. Nintendo DS Lite Lower Screen Replacement, Nintendo DS Lite Battery Disconnect: 步骤 1 中的图像 1,1
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
    添加评论
  2. Nintendo DS Lite Lower Screen Replacement: 步骤 2 中的图像 1,1
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
    询问修复机器人
    添加评论
  3. Nintendo DS Lite Lower Screen Replacement: 步骤 3 中的图像 1,2 Nintendo DS Lite Lower Screen Replacement: 步骤 3 中的图像 2,2
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
    询问修复机器人
    添加评论
  4. Nintendo DS Lite Lower Screen Replacement, Disassembling Nintendo DS Lite Bottom Case: 步骤 4 中的图像 1,1
    • Remove the following seven screws that secure the lower case to the DS Lite:
    • Three silver tri-point screws (5mm long)
    • One black tri-point screw (4mm)
    • Two gold Phillips screws (4mm)
    • One silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
    添加评论
  5. Nintendo DS Lite Lower Screen Replacement: 步骤 5 中的图像 1,1
    • On the front edge of the Nintendo DS between the headphone jack plug and volume controls remove the plastic insert (or cartridge) from the lower slot (Slot 2).
    询问修复机器人
    添加评论
  6. Nintendo DS Lite Lower Screen Replacement: 步骤 6 中的图像 1,2 Nintendo DS Lite Lower Screen Replacement: 步骤 6 中的图像 2,2
    • Flip the unit over so that it is facing right-side up.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
    询问修复机器人
    添加评论
  7. Nintendo DS Lite Lower Screen Replacement: 步骤 7 中的图像 1,3 Nintendo DS Lite Lower Screen Replacement: 步骤 7 中的图像 2,3 Nintendo DS Lite Lower Screen Replacement: 步骤 7 中的图像 3,3
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power and volume switch covers on the bottom case are aligned with the switches on the board to avoid breakage.
    询问修复机器人
    添加评论
  8. Nintendo DS Lite Lower Screen Replacement, Lower Screen: 步骤 8 中的图像 1,1
    • Remove the two screws holding the motherboard to the rest of the device using a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  9. Nintendo DS Lite Lower Screen Replacement: 步骤 9 中的图像 1,2 Nintendo DS Lite Lower Screen Replacement: 步骤 9 中的图像 2,2
    • Locate the small ribbon cable that connects the touch screen to the motherboard. Do not pull on this cable.
    • Gently lift the hinged black cover on the connector.
    • The hinges are near where the ribbon is inserted.
    • After lifting the black cover, the ribbon cable will disconnect easily.
    添加评论
  10. Nintendo DS Lite Lower Screen Replacement: 步骤 10 中的图像 1,1
    • With a plastic opening tool, gently begin to separate the motherboard from the rest of the device.
    • The ribbon cable and two wires are still connected to the motherboard and the buttons tend to fall out.
    询问修复机器人
    添加评论
  11. Nintendo DS Lite Lower Screen Replacement: 步骤 11 中的图像 1,2 Nintendo DS Lite Lower Screen Replacement: 步骤 11 中的图像 2,2
    • Flip the motherboard over so the touch screen is facing up.
    询问修复机器人
    添加评论
  12. Nintendo DS Lite Lower Screen Replacement: 步骤 12 中的图像 1,1
    • Do not pull on the main ribbon cable.
    • Carefully lift the tiny hinged cover on the connector.
    • The ribbon cable will easily disconnect.
    • Remove the third ribbon cable the same way.
    询问修复机器人
    添加评论
  13. Nintendo DS Lite Lower Screen Replacement: 步骤 13 中的图像 1,1
    • There is nothing else connecting the touch screen. Just pick up and set aside.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
13等其他人完成本指南。
团队
Cal Poly, Team 16-30, Maness Winter 2010 Cal Poly, Team 16-30, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G30
4 名成员
创作了29篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 188
过去 30 天: 888
总计 31,062
