跳转到主内容
Nintendo 3DS 2015 Gamecard Reader Replacement
Tyler Starr
Tyler Starr2 其他贡献者
最后更新于 June 22, 2021
20分钟
中等
If your games won't load replacing the gamecard reader is an option. Watch out for delicate ribbon cables in the device.
你所需要的
工具
查看更多...
  1. Nintendo 3DS 2015 Gamecard Reader Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 2 中的图像 2,2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Gamecard Reader Replacement, SD Card Reader: 步骤 4 中的图像 1,1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 5 中的图像 1,1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 6 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 6 中的图像 2,2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
    Where can I buy a new SD card reader? Cant seem to find any.
    Aldair - 回复
  7. Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: 步骤 7 中的图像 1,3 Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: 步骤 7 中的图像 2,3 Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 8 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 8 中的图像 2,2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 9 中的图像 1,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 9 中的图像 2,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 9 中的图像 3,3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Gamecard Reader Replacement, Gamecard Reader: 步骤 10 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement, Gamecard Reader: 步骤 10 中的图像 2,2
    • Locate the gamecard reader near the bottom right corner of the motherboard.
    • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
    • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
  11. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 11 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 11 中的图像 2,2
    • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
    • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
结论
3等其他人完成本指南。
Tyler Starr
于10/06/16注册
1,696 声望
创作了7篇指南
团队
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G6
4 名成员
创作了35篇指南
3指南评论
Where can I find this replacement Part?
Sean Taylor - 回复
Hello! Unfortunately replacement parts for this particular model are difficult to find. There seems to be some replacement parts for the XL; however, I don't think that they are the compatible with the regular 3ds. Additionally, slot replacements are sold widely; however, it would require difficult smd rework. Your best bet is to find a New 3ds 2015 that is being sold for parts on ebay that has a working gamecard reader and use that as a replacement.
Tyler Starr -
Does anyone know a replacement part link for this? I don't have the money for another one.
aiden owens - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 75
过去 30 天: 238
总计 5,628
