跳转到主内容
Nintendo 3DS 2015 Battery Replacement
Tyler Starr
Tyler Starr4 其他贡献者
最后更新于 April 1, 2025
5分钟
简单
If your battery isn't holding a charge or won't charge you may consider replacing the battery. Press hard and go slow on the screws in the back panel they are soft and strip easily.
你所需要的
配件
工具
查看更多...
  1. Nintendo 3DS 2015 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Battery Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS 2015 Battery Replacement: 步骤 2 中的图像 2,2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Battery Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS 2015 Battery Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS 2015 Battery Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
结论
7等其他人完成本指南。
Tyler Starr
于10/06/16注册
1,696 声望
创作了7篇指南
团队
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G6
4 名成员
创作了35篇指南
5指南评论
The link to the Nintendo store to buy a battery no longer functions.
David Clarke - 回复
My console has been off and without a battery for months now and I haven't been able to get a replacement battery until very recently, I replaced it just now and the orange led lights on (albeit for a short time) but the console won't turn on. The blue led lights up briefly then goes out again and the console remains off. Could it be something wrong with the console itself rather than the battery? Edit: Should I just leave it plugged in for a while even if the orange led doesn't stay on?
Leon J - 回复
I solved it by cleaning the contacts, reseating the battery and removing the microSD card. The SD card can then be put back in later
Leon J -
How's the battery life on it so far? I know you just posted 2 days ago, but I was just curious.
Will Reds -
i bought one of these batteries but it’s slightly smaller than the original battery and and the charge does not last long, maybe 1-2 hours
Jessica V - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 62
过去 30 天: 346
总计 7,931
