跳转到主内容
加入维修社区 - 创建账户
Nintendo 2DS Volume Slider Replacement
你所需要的
  1. Nintendo 2DS Volume Slider Replacement, Volume Slider: 步骤 1 中的图像 1,3 Nintendo 2DS Volume Slider Replacement, Volume Slider: 步骤 1 中的图像 2,3 Nintendo 2DS Volume Slider Replacement, Volume Slider: 步骤 1 中的图像 3,3
    • Turn the 2DS over so that the backside is facing upwards.
    • Identify the two Phillips #00 screws on the upper rear panel.
    询问修复机器人
    添加评论
  2. Nintendo 2DS Volume Slider Replacement: 步骤 2 中的图像 1,3 Nintendo 2DS Volume Slider Replacement: 步骤 2 中的图像 2,3 Nintendo 2DS Volume Slider Replacement: 步骤 2 中的图像 3,3
    • Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
    • The screws are captive and will not detach from the back panel or separate from the panel upon removal.
    • Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
    • Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
    询问修复机器人
    添加评论
  3. Nintendo 2DS Volume Slider Replacement: 步骤 3 中的图像 1,3 Nintendo 2DS Volume Slider Replacement: 步骤 3 中的图像 2,3 Nintendo 2DS Volume Slider Replacement: 步骤 3 中的图像 3,3
    • Use your finger or a spudger to lift and pull the battery outwards from the side closest to the outer edge.
    询问修复机器人
    添加评论
  4. Nintendo 2DS Volume Slider Replacement: 步骤 4 中的图像 1,3 Nintendo 2DS Volume Slider Replacement: 步骤 4 中的图像 2,3 Nintendo 2DS Volume Slider Replacement: 步骤 4 中的图像 3,3
    • Pull the stylus out from the middle of the left edge of the device.
    • Use a Phillips #00 screwdriver to remove ten 2.0 mm screws from the back panel.
    • Unlike the top rear panel, these screws come out, so be sure to keep them in a safe place.
    询问修复机器人
    添加评论
  5. Nintendo 2DS Volume Slider Replacement: 步骤 5 中的图像 1,3 Nintendo 2DS Volume Slider Replacement: 步骤 5 中的图像 2,3 Nintendo 2DS Volume Slider Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
    • Don't yank or pull the back case off because the camera ribbon is attached to the motherboard and back case and may rip or damage the cable or camera itself.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
    • Use your spudger to gently slide the cable out of the connector.
    • Remove the back case.
    询问修复机器人
    添加评论
  6. Nintendo 2DS Volume Slider Replacement: 步骤 6 中的图像 1,3 Nintendo 2DS Volume Slider Replacement: 步骤 6 中的图像 2,3 Nintendo 2DS Volume Slider Replacement: 步骤 6 中的图像 3,3
    • Gently pry the side that holds the volume slider off of the 2DS.
    询问修复机器人
    添加评论
  7. Nintendo 2DS Volume Slider Replacement: 步骤 7 中的图像 1,3 Nintendo 2DS Volume Slider Replacement: 步骤 7 中的图像 2,3 Nintendo 2DS Volume Slider Replacement: 步骤 7 中的图像 3,3
    • Remove the volume slider from the sidebar housing.
    • When reassembling, ensure that the volume slider is volume slider is connected to the slider on the motherboard labeled VR1.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
S. Leng
于10/24/22注册
166 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 59
过去 30 天: 244
总计 6,649
