跳转到主内容
加入维修社区 - 创建账户
Nikon D80 Main Board Replacement
你所需要的
    1. Nikon D80 Main Board Replacement, Main Board: 步骤 1 中的图像 1,2 Nikon D80 Main Board Replacement, Main Board: 步骤 1 中的图像 2,2
      • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
      询问修复机器人
      添加评论
    2. Nikon D80 Main Board Replacement: 步骤 2 中的图像 1,3 Nikon D80 Main Board Replacement: 步骤 2 中的图像 2,3 Nikon D80 Main Board Replacement: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
      • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
      • Remove the back cover.
      询问修复机器人
      添加评论
    3. Nikon D80 Main Board Replacement: 步骤 3 中的图像 1,3 Nikon D80 Main Board Replacement: 步骤 3 中的图像 2,3 Nikon D80 Main Board Replacement: 步骤 3 中的图像 3,3
      • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
      • Remove the back plate that covers the main board.
      询问修复机器人
      添加评论
    4. Nikon D80 Main Board Replacement: 步骤 4 中的图像 1,2 Nikon D80 Main Board Replacement: 步骤 4 中的图像 2,2
      • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
      询问修复机器人
      添加评论
    5. Nikon D80 Main Board Replacement: 步骤 5 中的图像 1,1
      • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
      • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
      • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
      • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
      • Disconnect the main board from the two ports on the left by pulling the main board to the right.
      询问修复机器人
      添加评论
    6. Nikon D80 Main Board Replacement: 步骤 6 中的图像 1,3 Nikon D80 Main Board Replacement: 步骤 6 中的图像 2,3 Nikon D80 Main Board Replacement: 步骤 6 中的图像 3,3
      • Using the soldering iron, disconnect the four wires soldered to the main board.
      • For more information on how to solder and desolder connections, please visit this guide.
      • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
      • Remove the main board.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Sara Martin
于10/09/17注册
610 声望
创作了4篇指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G1
4 名成员
创作了5篇指南
1指南评论
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 40
总计 3,335
