跳转到主内容
Nikon Coolpix S8200 CCD Lens Replacement
Nelson Antiposti
Nelson Antiposti6 其他贡献者
最后更新于 August 12, 2020
10分钟
中等
If you have continually received a lens error on your camera and restarting it doesn't help, then you need to replace the CCD lens. This guide walks you through the steps necessary to replace the CCD lens on the Nikon Coolpix S8200.
你所需要的
工具
  1. Nikon Coolpix S8200 CCD Lens Replacement, CCD Lens: 步骤 1 中的图像 1,1
    • First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
    • Be careful not to remove any extra screws.
  2. Nikon Coolpix S8200 CCD Lens Replacement: 步骤 2 中的图像 1,1
    • Once the back is removed, Do Not remove the ribbon cables shown in the within the red circles on the image.
  3. Nikon Coolpix S8200 CCD Lens Replacement: 步骤 3 中的图像 1,1
    • Unscrew the two screws around the silver disk-like part indicated by the red circles on the image and then remove them.
    • Next gently remove the black strap indicated by the yellow circle on the image.
    • The black strap can easily snap back on for reassembly.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 5-3, Kish Spring 2015 UMass Dartmouth, Team 5-3, Kish Spring 2015 的会员
UMASSD-KISH-S15S5G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 33
总计 2,350
