跳转到主内容
Nikon Coolpix S70 Display Screen Replacement
Danielle Morris
Danielle Morris4 其他贡献者
最后更新于 January 20, 2018
5 - 10 分钟
中等
特色学生指南
This guide will assist you in replacing your broken, cracked or malfunctioning display screen. For this replacement you will need a Phillips #000 screwdriver and a plastic opening tool.
你所需要的
工具
查看更多...
  1. Nikon Coolpix S70 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,2 Nikon Coolpix S70 Display Screen Replacement, Display Screen: 步骤 1 中的图像 2,2
    • Power off the camera before beginning.
    • Remove the battery by sliding the latch located at the bottom of the camera.
  2. Nikon Coolpix S70 Display Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S70 Display Screen Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera.
  3. Nikon Coolpix S70 Display Screen Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix S70 Display Screen Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix S70 Display Screen Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to carefully separate the back panel of the camera.
    • Once loosened, use your fingers to manually separate the two panels.
  4. Nikon Coolpix S70 Display Screen Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S70 Display Screen Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S70 Display Screen Replacement: 步骤 4 中的图像 3,3
    • Using a plastic opening tool, lift both latches that hold the ribbon cables in place.
  5. Nikon Coolpix S70 Display Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully disconnect the orange flat ribbon cables from the latches.
  6. Nikon Coolpix S70 Display Screen Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix S70 Display Screen Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix S70 Display Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the screen from the case of the camera by carefully pushing on the back of the screen.
    • You may need to push with a little force to get the screen to loosen.
结论
4等其他人完成本指南。
团队
Texas Tech, Team 22-2, Rauch Fall 2015 Texas Tech, Team 22-2, Rauch Fall 2015 的会员
TTU-RAUCH-F15S22G2
3 名成员
创作了1篇指南
1指南评论
my camera's lens show blury photos and when zooming id makes sound
Aliudin Saleh - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 1,238
