跳转到主内容
Nikon Coolpix S4100 Functional Button Plate Replacement
Matthew Willis
Matthew Willis5 其他贡献者
最后更新于 May 7, 2024
10分钟
中等
标记错误
需要更多图片
If you need to replace the video record, playback, or camera mode buttons, then you must follow these steps to replace the metal plate with the mounted wiring.
你所需要的
工具
查看更多...
  1. Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: 步骤 1 中的图像 1,3 Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: 步骤 1 中的图像 2,3 Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: 步骤 1 中的图像 3,3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 2 中的图像 1,1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 3 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 4 中的图像 3,3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 5 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 6 中的图像 2,2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 7 中的图像 1,3 Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 7 中的图像 2,3 Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 7 中的图像 3,3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 8 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 9 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 10 中的图像 1,1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 11 中的图像 1,1
    • Remove the top shell casing.
  12. Nikon Coolpix S4100 Functional Button Plate Replacement, Functional Button Plate: 步骤 12 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
  13. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
  14. Nikon Coolpix S4100 Functional Button Plate Replacement: 步骤 14 中的图像 1,1
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
结论
另外一个人完成了本指南。
Matthew Willis
于09/22/15注册
598 声望
创作了4篇指南
团队
Baylor, Team 4-2, Williams Fall 2015 Baylor, Team 4-2, Williams Fall 2015 的会员
BU-WILLIAMS-F15S4G2
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 414
