跳转到主内容
Nikon Coolpix S3500 LCD Screen Replacement
Sales Cameraparts4you
Sales Cameraparts4you3 其他贡献者
最后更新于 May 7, 2024
30分钟
中等
社区贡献指南
Nikon S3500 Disassembly and how to replace your existing damaged broken LCD.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Nikon Coolpix S3500 LCD Screen Replacement, Remove Bottom Screws: 步骤 1 中的图像 1,2 Nikon Coolpix S3500 LCD Screen Replacement, Remove Bottom Screws: 步骤 1 中的图像 2,2
    • Make sure to remove the battery - memory card - strap from the unit.
    • Remove 2 (4mm) screws from the bottom of the camera.
    • Remove 2 (4mm) screws from the bottom side of the camera.
  2. Nikon Coolpix S3500 LCD Screen Replacement, Remove Side Screws: 步骤 2 中的图像 1,2 Nikon Coolpix S3500 LCD Screen Replacement, Remove Side Screws: 步骤 2 中的图像 2,2
    • Remove 2 (4mm) screws from the right side of the camera.
    • Remove 2 (4mm) screws from the left side of the camera.
  3. Nikon Coolpix S3500 LCD Screen Replacement, Remove Rear Cover: 步骤 3 中的图像 1,3 Nikon Coolpix S3500 LCD Screen Replacement, Remove Rear Cover: 步骤 3 中的图像 2,3 Nikon Coolpix S3500 LCD Screen Replacement, Remove Rear Cover: 步骤 3 中的图像 3,3
    • Use a spudger or other plastic tool and carefully work your way around the seam and carefully Pry off the rear case.
    • Carefull not to loose the A/V Out cover. Remove it and set it aside.
  4. Nikon Coolpix S3500 LCD Screen Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix S3500 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Shock Hazard! Do not touch anywhere along the top panel. Capacitor will still hold a residual charge that will shock you if touched. It is best to discharge the capacitor using the two metal solder joints on the top panel in front of the black tape
    • Remove 1 (3mm) screw from the right side of unit.
  5. Nikon Coolpix S3500 LCD Screen Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix S3500 LCD Screen Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix S3500 LCD Screen Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Release Flex Cable from socket. Remove carefully. Just pull it out using tweezers or similar tool.
    • Slide the Rear Buttons ASSY to the right and them remove it
  6. Nikon Coolpix S3500 LCD Screen Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix S3500 LCD Screen Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix S3500 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Release the cable clamp using a spudger or similar tool.. or just use your fingernail. Be careful because the clamp breaks easily. Another way to release the cable is to just pull the LCD cable out carefully... this will automatically release the clamp without the risk of damaging the clamp
    • If you decide to pull the cable out make sure you hold the flex cable tightly and pull horizontal to its installed position away from the clamp. Do not hold the LCD!!! Hold only the flex cable and hold it tight.
    • Example photos of open and closed ziff socket clamps
  7. Nikon Coolpix S3500 LCD Screen Replacement, Install New Screen: 步骤 7 中的图像 1,1
    • Remove the LCD and Install the replacement Screen. Reverse the instructions to Assemble the unit
结论
1指南评论
The screen worked great. However, it now displays in negative. Images stored are in the proper colors. Do I need to back to re-check any item(s)?
Emil Scully - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 39
总计 1,515
