跳转到主内容
Nikon Coolpix S3100 Camera Shutter Button Replacement
Jorge
Jorge2 其他贡献者
最后更新于 July 23, 2020
没有估计
中等
The shutter button seems to malfunction whether it is not turning or not working. This guide will help you understand the problem.
你所需要的
工具
  1. Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 1,3 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 2,3 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 3,3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Shutter Button Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S3100 Camera Shutter Button Replacement: 步骤 2 中的图像 2,2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Shutter Button Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S3100 Camera Shutter Button Replacement: 步骤 3 中的图像 2,2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Shutter Button Replacement, Shutter Button: 步骤 4 中的图像 1,1
    • Turn and hold the shutter bottom to the left and using a tweezer carefully remove the spring.
    • Be very carefully handling the spring as it could release from tweezer.
  5. Nikon Coolpix S3100 Camera Shutter Button Replacement: 步骤 5 中的图像 1,1
    • Gently remove the black adhesive tape.
  6. Nikon Coolpix S3100 Camera Shutter Button Replacement: 步骤 6 中的图像 1,1
    • Remove 2-2.90mm using a #000 Phillips screwdriver.
  7. Nikon Coolpix S3100 Camera Shutter Button Replacement: 步骤 7 中的图像 1,1
    • The camera shutter is now apart.
结论
另外一个人完成了本指南。
Jorge
于03/11/15注册
1,170 声望
创作了7篇指南
团队
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G4
2 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 18
过去 30 天: 20
总计 596
